Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 12-23-2003, 11:01 PM
masic_2000 masic_2000 is offline
Rear klunking sound.
Hi:
Everytime I hit a certain bump on the road I hear this rear klunking sound from what seems like the rear suspension. Very hard to pinpoint as the car needs to be moving. I removed everything from the trunk to see if any difference. Still the same. It must come from underneath somewhere. Anyone experience this?
Thanks for reading.
Old 12-24-2003, 04:20 PM
csaxon csaxon is offline
Re: Rear klunking sound.
Could be this from a TSB. Camry (NAP) vehicles may exhibit a thumping/knocking noise from the rear suspension. Use the following instructions to repair the noise.
Remove rear seat cushion assembly and rear side seat back assembly.
2. Confirm rear upper strut nut torque.
Torque: 49 Nm (500 kfgcm, 36 ftlbs).
Old 12-24-2003, 04:26 PM
The above is the Toyota TSB from Jan15 2003. But you might crawl under the car and look for loose items such as exhaust pipe hangars etc or fuel lines that are loose. Bring some wrenches or ratchets wit you and tighten things up
Old 12-25-2003, 06:24 PM
Thanks.
I'll check it out.
Old 12-26-2003, 10:49 PM
yotatechie04's Avatar
yotatechie04 yotatechie04 is offline
Send a message via ICQ to yotatechie04 Send a message via AIM to yotatechie04 Send a message via MSN to yotatechie04 Send a message via Yahoo to yotatechie04
I'm having the same problem coming from the front of my '99. Should I just go and check to make sure that everything's tight, or what? Is there anything else I can do for this? It's a real pain in the ass.
1994 Pontiac Grand Am GT - 3100 V6
1992 Chevrolet Lumina Euro - 3100 V6
1997 Ford Escort - 2.0 I4
"She only squeals when she's wet..."
Old 01-10-2004, 03:43 PM
BMW_4.4i's Avatar
BMW_4.4i BMW_4.4i is offline
I would have to agree with "csaxon", but it may be something as simple as the trunk lid being slightly loose. I am not sure. Just a thought.
Old 02-02-2004, 01:47 AM
medic9593 medic9593 is offline
Re: rear Banging noise.
Hey guys, your clunking sound is probably the rear swaybar bushings and rear swaybar links. The bushings are on the frame and are held in with small metal clips and rusted bolts. The swaybars links are attached to your shock and the swaybar.( Link is dealer item). Look for broken rubber "boots" on the link. Good luck!
Don
Old 02-04-2004, 11:54 PM
Thanks Don, I'll check it out.
Old 02-05-2004, 12:44 AM
Big blue truck Big blue truck is offline
14 years toyota tech I would say its rear swaybar bushings
Old 02-22-2004, 09:05 PM
rogedmonds rogedmonds is offline
Rear Clunking sound
I have a 93 Camry w/273,000 miles on it. I had the same problem. On mine it was the lower control arm on the passenger side. To check it jack the car up until the rear wheels are off the ground and grab the tire on the front and rear and see if you can wiggle it back and forth. The play would be either where the lower control arm connects near the bottom of the rotor spindle or where the lower control arm connects to the rear suspension cross-member. Mine was at the rotor spindle. I removed the entire rear suspension and replaced the lower control arm. The problem is gone.
Old 02-23-2004, 11:33 PM
Thanks.
More things to check.
Old 02-25-2004, 09:56 PM
fredbros72 fredbros72 is offline
Originally Posted by masic_2000
Hi:
Thanks for reading.
hi there
odds are the noise is coming from rear sway bar bushings, there is a long bar that stretches across the rear, rubber bushings hold this bar in place, they wear over time, and the bar will make a clunking sound,
pretty easy to replace, two 12 mm bolts,
one other possibility, rear struts, rear strut mounts
but check out the bushings first
Old 02-25-2004, 09:58 PM
Re: Re: Rear klunking sound.
hey,
the noise you are probably hearing is coming from the front strut mounts,
the nuts tend to loosen up on the top of the struts
take a 19mm socket and try to tighten the upper strut nuts,
if not will need to be replaced, can be expensive
Rear suspension sound: Strut mounts? olopezm Grand Prix 27 12-29-2010 12:51 PM
Clunking noise in Rear End. Sounds like I was rear ended. 2madrns M Bodies 6 10-30-2004 10:26 PM
rear speakers sound bad? why? brent07_07 Intrepid 8 08-06-2004 09:10 AM
Rear rattle sound... PLEASE HELP!!! Maxima 2k max4 Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 1 01-06-2004 09:14 PM
New rear speakers sound like crap.... HELP jewelerz Audio/Security 6 01-31-2002 10:50 AM
