Old 12-23-2003, 10:12 PM
Speed Racer Speed Racer is offline
Big Engines?
Hey does anybody know whether the F20C or the K20A engines will fit in the CRX? I know that with the right amount of money anything can be done. I don't want to destroy the chassis AT ALL, nor do I want to have it sticking out of the car. Engine mounts, wiring, removing a/c, heating, or battery can be done. Check back in a little while. If you want to see these stats look no further than http://www.hondaswap.com/reference/i...hp?mode=engine
The cause of all the corruption on the Earth, is due to man and his imperfection ; GREED!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old 12-23-2003, 11:02 PM
91civicDXdude's Avatar
good luck... the F20C is the accord/prelude series of engines, and in order to put them in the car, the chassis must be butchered to fit.
The K series has yet to be experimented on, but plan on spendin about 10,000 to drop that in your car..
Old 12-23-2003, 11:22 PM
Kunundrum's Avatar
Kunundrum Kunundrum is offline
Send a message via ICQ to Kunundrum Send a message via MSN to Kunundrum
the F20C is a S2000 Motor and the K20a is a 2002+ RSX-S or Civic Si(R) Motor... good try though.
With enough money & knowhow anything is possible... Like today I took a drive in a 4G63T Powered 5th Gen civic.
2012 VW Golf 3 Door Automatic (Company Car)
2011 VW Golf Wagon 5 speed (Company Car)
2010 VW Jetta 2.5 Automatic (Company Car)
2009 VW City Jetta 5 Speed (Company Car)
2009 VW GLI 6 Speed (Company Car)
2008 VW Jetta 2.0T 6speed (Company Car)
1999.5 Audi A4 Quattro Sport 1.8t (Chipped 1.0 bar) Sold
1990 CRX Si (Built B17a) - Stripped and Crushed
1988 CRX Si -- Stolen
1990 Civic Cx -- Sold
1990 Civic Si -- Parted
1989 Civic dx -- Sold
Old 12-23-2003, 11:44 PM
Ace$nyper's Avatar
Ace$nyper Ace$nyper is offline
Banned
Send a message via AIM to Ace$nyper Send a message via MSN to Ace$nyper Send a message via Yahoo to Ace$nyper
me got a hemi!
Old 12-24-2003, 12:52 AM
Re: Big Engines?
my bad, i was thinking of the F20B...
Old 12-24-2003, 01:33 AM
Worth a shot at the least. I have heard that with the K20a engine you have to mount it backwards or something like that.
Old 12-24-2003, 02:19 AM
optimuscivic's Avatar
optimuscivic optimuscivic is offline
Re: Big Engines?
why would someone do that swap?
edit: just read your post on it.
As American As A Burrito!
USDM 4 life!
Old 12-24-2003, 09:43 AM
bambam89lx's Avatar
bambam89lx bambam89lx is offline
AF - Advisor
Send a message via AIM to bambam89lx
Re: Big Engines?
1. The F20 has never been put in a prelude, nor any other fseries motor. They've always been B's and H's
2.Yes, the Kseries has been experimentin' on. It has been swapped into a 4thgen. I'm pretty sure that motor mounts will be available for that swap some time in 04.
Jumper harnesses, mpfi conversions, engine harness conversions, vtec subharnesses, etc.
The absolute lowest prices at the absolute highest quality. Trusted. Guaranteed.
Click the image above to visit our online store!
Hastings Bseries and Dseries piston ring kits (inc. ZC) - $49 shipped
Old 12-24-2003, 12:03 PM
I thought he was speaking of the Accord Euro R engine, the F20B, which, btw, shares the same chassis as the prelude. this is why an H series will bolt into an F series accord chassis.
Oh, and good luck waiting on that 4th gen K series mount kit.
Old 12-24-2003, 12:10 PM
gunnmen01's Avatar
gunnmen01 gunnmen01 is offline
Send a message via AIM to gunnmen01 Send a message via Yahoo to gunnmen01
The 4th gen prelude s had the f series single cam from the accord in it, for awhile, after they changed body styles in 97 they didnt have the f anymore...
gunnmen01
My other ride..... is YOUR MOM !!!!!!
Old 12-24-2003, 12:19 PM
dxhatchback dxhatchback is offline
Re: Big Engines?
here he comes
here comes SPEED RACER!!
HONDA is the BOMB!
Old 12-24-2003, 01:42 PM
kris's Avatar
kris kris is offline
Off playing with fire.
Re: Big Engines?
I have a stock F20B motor here, running 7 lbs of boost, and it ran a 11.6.
Old 12-24-2003, 02:03 PM
bambam89lx's Avatar
AF - Advisor
Re: Big Engines?
Sorry, I was wrong about one thing.....the Prelude did come with F22's in the non vtec 92-96's. But they didn't come with F20's. Sorry for the mistake.
Old 12-24-2003, 03:04 PM
EF You's Avatar
EF You EF You is offline
EF Life Giver
Send a message via AIM to EF You
Re: Big Engines?
that is the most preposterous thing ive heard lately. think about that for one second more. if you put the engine in backwards, the shift linkage would not operate properly, everything about it would be backwards. so to go forward you would have to put it in reverse. just because the engine rotates a different direction doesnt mean you have to go flipping things around. if you took the entire drivetrain from the rsx and put it in the civic chassis, once you got it all attached to the chassis, it is just like any other car. have you looked in an engine bay of a civic without an engine in it? there is really no indication that the engine should be on one side and that the tranny should be on the other side. all you see is a mounting bracket on each fender well. with custom mounts, its probably pretty close to being as easy as a bseries, except for the massive wiring change, and the difference in shift linkage. but mechanically, i dont see it being all that difficult once you fabricate the proper brackets for linkages and mounts. then again, you do have to convert to hydro clutch, but you dont have to fabricate stuff for power steering, which makes it a lot easier.
but to even think that you need to put the engine in backwards is just plain dumb
over 10 grand in parts, and about 300 hours of labor, and i only spent 3k. and then Katrina filled it with mud.
Old 12-24-2003, 03:32 PM
bambam89lx's Avatar
AF - Advisor
Re: Re: Big Engines?
Right...while we're on the thought of swapping in an engine.....
You can swap in any engine from any car into any other car that you want...as long as you have the time and the money.
You need 3 important things to make ANY swap work:
1.)wiring harness adapter
2.)shift linkage
3.)Engine Mounts
The only reason that this swap is difficult to do is because none of the 3 things listed above are "widely available, mass produced, consumer" products.
Think about it. Back in 92 or something, people weren't swapping B-series engines into the 88-91 civics...they thought it was "impossible"......why? Because none of those three things were available yet. When people DID actually start to do that stuff, those three things had to be custom made or fabricated. Then when more and more people wanted to do that swap...companies began making the 3 products that u need to get that swap done....they waited until there was a demand for those products before they began making them. Give it 1 or 2 yrs. After that, those three things listed above WILL be available widely for K-series engines into a civic/crx. Then people all over will start swapping that engine in. But, the Kseries engine DOES fit into our chassis.
Anyone get wut I am saying?
You can get any engine to run any car if you wanted too..........Does anyone ever watch "Junkyard Wars"?.......LOL
Remember......we drive "HONDAS!!!" Which means we can put any engine in our cars.
86 buick lesabre estate wagon with 70's olds 455 big block engine in need of help kcbuechler LeSabre 29 06-26-2012 10:21 AM
You think you have a big engine??? Hypsi87 Street Racing 38 03-04-2005 03:45 PM
Big Rims and Big Engines Stopshootn Tires and Wheels 6 01-07-2005 05:32 PM
And domestics think they have big engines... JekylandHyde Street Racing 9 09-22-2003 08:46 PM
Big BIG Engine Trouble joetcm Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 3 01-08-2003 10:52 AM
