Old 12-23-2003, 08:52 AM
mingas mingas is offline
Question heater and defrost on 1988 silverado
My question is concerning the heater and defrost setting on my truck. I've owned this truck for 15 years and have done most of the fix-it work myself, but this one has me stumped. The AC and heater works good when it comes to temprature. The problem is the direction of the air. It doesn't matter what setting you put the control on the air will just blow out the AC vents. The indicator bar on the dash shows it to be on defrost or heater and the air feels hot but the air doesn't blow out of the floor vents or windshield vents. If you have any sugestions please advise me of them. The frost on the windshield in the morning has become a real problem here lately.
Thanks, Mingas
Old 12-28-2003, 06:41 PM
gearhear gearhear is offline
Cool
im not sure but i think the mode door is vacuum operated. if so check to make sure that the hose coming from the engine and going inside is not broke or disconnected. otherwise there would be a cable behind the dash that could be disconnected if it is manual.
Old 12-29-2003, 01:53 PM
Re: heater and defrost on 1988 silverado
It is vacum operated and I'll check for any bad vacum hoses. Thanks, Mingas
Old 02-10-2004, 01:24 PM
eaglewisard eaglewisard is offline
if you have or have had any clicking doors are electric
Old 02-12-2004, 06:17 PM
w.t.f.are you talking about?
Old 02-12-2004, 06:50 PM
Bronco2 Bronco2 is offline
Your HVAC system is electronic, not vacuum. Your problem is not unusual,replacement of the control head (heater control panel) should fix the prob.
97 k1500 z71 silverado, BLOW THE HEATER CORE???? kokopelli85 Silverado 6 01-12-2010 07:38 PM
1988 Silverado 3/4 Ton 350 Auto. Odometer and trip doesnt work. How do I fix? nx02nx02 Silverado 2 10-11-2006 08:16 AM
Heater and Defroster detourguy Thunderbird 2 03-02-2005 10:49 PM
1988 silverado 5.7 engine and towing specs mbflyer C/K 0 05-11-2004 10:25 AM
heater and defrost problem 1988 silverado mingas C/K 2 12-29-2003 01:47 PM
