Go Back   Automotive Forums Car Chat > GMC > Sonoma | S-15
Old 12-22-2003, 12:20 AM
justinthehead85 justinthehead85 is offline
gas gauge
I have a 97 sonoma that i just recently bought and the gas gauge is reading wrong. Im not sure what it is because it reads right a fews times. when i start the truck it goes down to where it should be and goes to above full tank of gas. i was wanting to hear any replys about what you might think it is. thanks
Old 01-05-2004, 10:41 AM
Jezzka Jezzka is offline
Send a message via AIM to Jezzka Send a message via Yahoo to Jezzka
Re: gas gauge
I am not too sure of what your problem is, but I do have a suggestion for you. Maybe your tank needs to be cleaned out. I know that helped my old Monte Carlo. All we did was take apart the tank reposition the anti-reversion valve and the gauge was reading normal. I hope this may have helped some.
Old 01-12-2004, 10:36 PM
herefordman herefordman is offline
Re: gas gauge
Theres' probably a ground problem from the tank to the frame, or it may be the voltage regulator that modulates the guage itself
Old 03-21-2005, 10:17 PM
dody dody is offline
Re: gas gauge
Recently got a 99 Sonoma 4.3L and have a similar
gauge problem. Show full most of time and never
gives right reading. Wonder if you found your problem
sounds like it might be the same as mine. Would
appreciate any help. THANKS
Old 04-02-2005, 11:27 AM
b20b_ek b20b_ek is offline
Re: Re: gas gauge
bump because i have the same problem
Old 04-03-2005, 07:15 AM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
Re: gas gauge
It's your sending unit. Unless you want to spend the money on a new sending unit, learn to live with it.
Old 04-11-2005, 12:18 AM
two-wayman two-wayman is offline
I have an 01 sonoma with a similar problem. Mine tank is empty when it hits a quarter of a tank. The fuel pump was replaced at 19,000 miles and now I have 50,000 and just the other day I found out that when I hit a quarter of a tank im out of gas or so the guage reads a quarter of a tank. Normally I fill my truck up before I hit a quarter of a tank but its kinda wierd. I think they either positioned the float incorrectly or there is something wrong with the sending unit itsself.
Help gas gauge does not work right and is not taking gas well!!! spflick Taurus | Taurus Wagon 9 08-05-2007 03:21 PM
temp gauge and gas gauge shaolyn '88 - '91 Civic | CRX | Wagon | Shuttlee 3 06-18-2005 03:59 PM
DIC gas gauge,speedometer, temp gauges not working hotep Aurora 7 05-09-2005 11:26 AM
Gas gauge stuck & no amp gauge makailaann Ram Pickup | Ram SRT10 1 05-09-2005 09:35 AM
gas gauge is stuck half way with full tank of gas jerom 3 Series 3 07-14-2003 08:50 PM
