Go Back   Automotive Forums Car Chat > Honda > Prelude
Old 12-21-2003, 11:34 AM
Bachan Bachan is offline
Angry 1991 prelude cylinder 1 not firing
Hi All,
My timing belt broke and after changing, I am getting vibration when the engine is running. seems to me that cylinder 1 is not firing, 2-3-4 are fine. when i pulled the cables from the spark plug, i can hear the engine hesistate and then back to normal. When i do the same for cylinder 1, i do not hear a difference as would the other cylinders.
All my cables are good, tested with meter. Changed cap and rotor.
Any suggestions??
Old 12-21-2003, 11:38 AM
BullShifter's Avatar
Re: 1991 prelude cylinder 1 not firing
Did you pull the plugs out?
How fast were you going/rpm when the timing belt broke?
Old 12-21-2003, 12:31 PM
Thanx for the reply,
I did pull the plugs out and make sure they are firing. used diferent cables and new plugs. I was doing about 80-90km when it happened.
83 cylinder not fireing heschlie Maintenance 6 03-24-2005 12:27 AM
2 cylinders not fireing? please help Mayday0017 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 4 02-05-2005 11:54 PM
need help one cylinder not fireing mano84 Camaro Discussions 20 02-05-2005 02:54 PM
help? 89 prelude si -- cylinder not firing dewzenol Prelude 2 11-16-2003 08:38 PM
