Old 01-28-2005, 11:31 AM
mano84 mano84 is offline
need help one cylinder not fireing
At idle my car runs very shaky and when im on the highway at about 1500 rpm my car shakes pretty bad. I just replaced my spark plugs and wires but that did not help at all. could it be a weak coil? i really have no idea whats up and i need some help please thanks.
Old 01-28-2005, 01:26 PM
Twizted_3KGT's Avatar
Twizted_3KGT Twizted_3KGT is offline
Re: need help one cylinder not fireing
so what makes you think a cylinder isn't firing? little more detail?
Old 01-28-2005, 04:46 PM
Savage Messiah's Avatar
Savage Messiah Savage Messiah is offline
Send a message via AIM to Savage Messiah Send a message via Yahoo to Savage Messiah
It's a pontiac shoulda bought Chevy
97 Camaro - 2.077 60', 14.745 @ 92.20 - still down, one year later.
194k miles-160* thermo-V8 shocks/springs (V6 rear springs)-3" Magnaflow !cat (3" dynomax bullet) back-SLP CAI-stock boxed LCAs-poly tranny mount and torque arm bushing-custom HPTuners tuning-4.10s/eaton/TA girdle-3.5" alum DS-spohn LCA brackets-prostar skinnies
179.75 RWHP, 204.52 RWTQ
ON ITS WAY: MORE
R.I.P. Andy
87 Benz 190e - DD
01 EX250 - still gotta get my license for this thing
Old 01-28-2005, 05:10 PM
chickenkicker's Avatar
chickenkicker chickenkicker is offline
Re: Re: need help one cylinder not fireing
Um both have the same engine, infact they're both 90% the same car.
Black 97 Trans Am M6 - TB Bypass, !CAGS, Manual Fan Switch, 1LE Elbow, K&N FIPK, SLP Loudmouth Exhaust, cross drilled and slotted rotors.
Click here to visit my CarDomain page
Old 01-28-2005, 05:27 PM
hotrod_chevyz's Avatar
hotrod_chevyz hotrod_chevyz is offline
If you gapped all the plugs right,and if the wires are installed correctly,then your next move should be checking each plug wire with a timing light.
If you go from one plug wire to the next,and with each you look the timing light in the eye,it will show you if any of them are missing or not.A good sign is a *steady intermittant* spark signal coming through the timing light.A bad signal is a *non-steady intermittant *spark signal.
If you dont have a timing light,you can pull each plug out and see if they all match,or if one or a few come back smelling of gas or fowled in any way other than normal plug wear.
An old school more brutal way of checking them,is using a pair of insulated pliars,and pulling off each wire as its running,to note the change of each you pull off.No change=no spark.
If none of that helps check the compression and compare each cylinder.More than 10% difference between any of them,And its going to shake no matter what.
If its about to swallow a valve,you can check it with a vaccume gauge.What you want to see on one of those is a nice steady signal between 13-18 inches mercury.
And finally i bring you to the cam.If you run the crap out of it or if its a high mile car,it might need a cam,timing set,or lifter/pushrod set.
It could be a bad coil,it could be a vaccume leak,or a bad gasket somewhere.
Old 01-28-2005, 08:05 PM
Re: Re: Re: need help one cylinder not fireing
Infidel!! You have chosen the inferior race!!!!
ON ITS WAY: MORE
R.I.P. Andy
87 Benz 190e - DD
Old 01-28-2005, 08:11 PM
Mr. Luos's Avatar
Mr. Luos Mr. Luos is offline
Firebird Guy
Re: Re: Re: Re: need help one cylinder not fireing
Right........
1999 Pontiac Trans Am WS.6 #1747
Stock'ish'
Old 01-28-2005, 08:24 PM
cough cough...cameros are stupid....cough cough....
Old 01-28-2005, 08:29 PM
I don't see what the big deal is 97CamaroRS and why you have to come on here and try to start trouble. With statements like the last 2 you made you're only trying to start an arguement. IMO neither Camaros or Firebirds are "inferior" they're basically the same car. I don't have a preferance one way or another. And if you want to debate the 2 start a new thread and don't clutter up one where someone is just trying to get a little help.
Old 01-28-2005, 09:07 PM
aww i think he was just funnin maybe, dont spin a main bearing over it kicker.Ive said some stuff jokingly,and ended up banned from the forum.
He has to know that we on the pontiac end of chevy are in with the excitement division.A SBC is awsome and i have one and its fast and omega concern of the ricers on my block>but you cant argue with the eye crossing dyno busting low end torque of a strung out 400 pontiac.
and for tpoics sake MANO84,have you ever had it put on a diagnostic,and is the check engine light on?
Old 01-29-2005, 10:38 AM
silver87ta's Avatar
silver87ta silver87ta is offline
sounded to me like it was some good-natured fun pokin, not like ricer bashin....
02 Formula 5.7L V8 LS1
SLP Lid, SLP MAF, SLP Cold-Air Induction, WS6 ViS Carbon Fiber hood
Gone but not forgotten: 87 Trans Am 5.7L V8
My first true addiction
Old 01-29-2005, 11:14 AM
FormulaLT1's Avatar
FormulaLT1 FormulaLT1 is offline
Fight the powwa!!!
Send a message via AIM to FormulaLT1 Send a message via MSN to FormulaLT1 Send a message via Yahoo to FormulaLT1
Yeah, Silver is right. I know this guy from over at the Camaro forum and outside the forum. He is just having some fun at his own expense after all you have to have a sense of humor to drive a Six cylinder sports car.(JK Hypsi and Everyone else I actually like the 3.8s)
RIP Hypsi - I just want to express I will never be the same after having lost such a good friend. You meant alot to me and I feel I am a better person for having known you. Til the day we meet again my friend you will always be in my heart.
Mods: Weight reduction (I don't wear underwear)
Old 02-04-2005, 10:17 AM
waipio waipio is offline
Had The Same Problem..was A Coil..need Special Size Socket And Mini-ratchet To Remove/replace..my Gm Buddy Removed Both Wires Per Coil And Found One With No Jumping Spark...that's The One! Good Luck!
Old 02-04-2005, 01:21 PM
Thumprkils's Avatar
Thumprkils Thumprkils is offline
Banned
Send a message via Yahoo to Thumprkils
hmm
Old 02-04-2005, 01:25 PM
Thumprkils's Avatar
Banned
in fir e or ?
let me see your camaro blink its eye lids
not to mention that lil spoiler on the back of your car , lol
