Go Back   Automotive Forums Car Chat > Nissan > 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX
Old 02-05-2005, 03:35 AM
Mayday0017 Mayday0017 is offline
Exclamation 2 cylinders not fireing? please help
Engine is only running off first 2 cylinders after engine swap. Checked timing, perfect. Checked plug wires and swapped with known good still nothing. Swapped plugs from rear two cylinders that arn't working with front two that are no difference. Swapped known good fuel rail with known good injectors. Still no difference. Used a multimeter and checked voltage from computer to injector at injector harness all showed aprox 1 volt. Car has new fuel pump and filter also. All plugs are getting spark. What else is there to check? Can two injectors be getting fuel and two injectors not? How can I tell for SURE that the rear two are even feeding fuel? Please give any suggestions possible I am really lost at this point.
Old 02-05-2005, 12:33 PM
logik23's Avatar
logik23 logik23 is offline
Banned
Send a message via MSN to logik23
Re: 2 cylinders not fireing? please help
Is it me or are you really not lucky? I mean you had these problems with the last engine, you couldn't sell the car and now that you've swapped the engine, the problems are starting all over again....Can't you just take out an injector and check if fuel comes out?
Old 02-05-2005, 01:05 PM
nissanfanatic nissanfanatic is offline
240SX Guy
Send a message via ICQ to nissanfanatic Send a message via AIM to nissanfanatic Send a message via MSN to nissanfanatic Send a message via Yahoo to nissanfanatic
I would check the compression in the back two. And make sure the injector insulator thingies(the little black rubber donuts) seal up with the injectors good. I would also check out the o rings.
To test if the injector o rings are good, hook up the feed and return lines to the fuel rail. Leave the fuel rail turn the key to the on position. The fuel pump shuts off after like 5 seconds if it doesn't detect 180* of crank rotation. To see if they work, haev someone crank the car over a few times with the same setup you had to see if they leaked and watch them to see if they spray. ******Keep a rag under the injectors during each test. If not, fuel is going to go everywhere if the o rings aren't sealed and/or when you test the injectors themselves.
-Cory
1992 Nissan 240sx KA24DE-Turbo: The Showcar
Stock internals. Daily driven.
12.6@122mph
496whp/436wtq at 25psi
Old 02-06-2005, 12:51 AM
I am stupid, no problems at all.... dad thought he would help and changed the order of my plug wires on the distributor and I assumed they were the same way I had left them last weekend.... Don't you love when people play with your toys? Engine swap was a success runs perfect better then my daily driver.
Old 02-06-2005, 12:54 AM
240SX Guy
Nice easy fix huh? Good luck with your new engine.
-Cory
12.6@122mph
