Old 12-21-2003, 11:26 AM
dtsryder dtsryder is offline
Question ?'s for v8 swap guys
i have a couple of questions about a v8 swap that i would like to do in my 94 2.2l s10.
1)what is a estimated cost to have a lt1,305, vortec swapped into my truck from a shop(labor only)?
2)how hard will it be to do w/ help myself?
3)could i use a camaro diff. and drive shaft?
4) what would the estimated cost of the engines? (i would have the engine rebuilt so mileage is not important)
late, i hope i get some responces
Old 12-21-2003, 05:49 PM
HONDABOND HONDABOND is offline
Re: ?'s for v8 swap guys
Ummm, $8000 total guestimate for a rebuilt and installed LT1.
White folk eat noodles too.
Old 12-23-2003, 11:12 AM
thats a lot of $$$. i was hopin to get close to 5-6k by using parts from another v-8 ride. is it possible to use a camaro or c10 rear end, and drive shaft?
Old 12-24-2003, 09:52 AM
Strongman00 Strongman00 is offline
If you are willing to pay $6000 then bring it to me. I'll put a 388 stroker in with a th400 trans, custom drive shaft and an auburn pro diff with your choice of gears. Aluminum heads nice headers edelbrock Air Gap intake and a Barry Grant carb.
I drive mine to work quite often, I am running to low of a gear though where it is set up for the 1/8th mile.
I am located in Darlington SC.
Old 12-28-2003, 04:59 AM
strongman that sounds dope but im just researchin cuz im goin to airbag my truck then in a about a year, engine swap
Old 01-02-2004, 10:27 AM
CADTECH023 CADTECH023 is offline
IF YOUR SERIOUS GET THE V-8 CONVERSION MANUEL FROM WWW.JAGSTHATRUN.COM
$30 BUT IT HAS SAVED ME TEN TIMES THAT IN PARTS DESIGN AND VERY IMPORTANTLY...TIME
GOOD LUCK AND $8000 IS PROBIBALLY ABOUT DOUBLE WHAT IT SHOULD COST. DO THE WORK YOURSELF AND SAVE SOME MONEY. GET ALL THE PARTS FIRST THEN POUND IT OUT IN A WEEK.
GOOD LUCK
Old 01-06-2004, 09:29 AM
jcas1411 jcas1411 is offline
I have had two swaps in the S-10 and it is not that hard with the right equipment. Buy the JTR V-8 swap manual before you start buying parts. It will save you alot of time and money. The diff of the S-10 should be fine with a stock LT1. With the LT1 or L98 be sure to pick up the painless engine harness to replace the stock harness. My first was a L-98 and now I am working on a 520 horse MFI 383 that has cost around 8500 to build. You should be able to find a LT1 or an L-98 for around 1200 complete and wiring will cost around 300. I think you should be able to do the complete job including 700R4 tranny for around 3500 if you do the labor.
Old 01-06-2004, 09:32 AM
sorry including machine work if rebuild is going to be around 6,000. You probably could find one in good condition at a salvage yard with low miles this would save you some bucks.
?'s about swapping ps and ac DSMNerd6889 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 1 08-07-2008 06:59 AM
Turbo ?'s for 99 gsr mk3jk Integra 9 04-19-2004 02:23 AM
Clear Corner ?'s For 03 Tib 1QUICK2 Tiburon | Tuscani 6 04-05-2004 11:04 AM
Couple ???'s for a Cav Newbie Taurus92AF Cavalier 7 05-09-2003 05:12 PM
exhuast ?'s for 240 sk8terCraig 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 8 10-19-2002 03:05 PM
