Go Back   Automotive Forums Car Chat > Hyundai > Tiburon | Tuscani
Old 04-01-2004, 09:08 AM
1QUICK2 1QUICK2 is offline
Clear Corner ?'s For 03 Tib
First of all that whole AF shutting down sucked ass for a minute
Now...a friend of mine at work told me that you can remove the orange lenses on the corner of the headlight on the 03 tib. Is this true? and how do you do it?
93 MR2 Turbo-.20 over JE pistons,T3/04E 57 trim w/.63 AR,Intake,Greddy profect b spec 2 BC, APEX'I GT spec exhaust,Apex-i S-AFC, Turbo timer,550cc injectors,HKS trunk mount IC, B&M s/s,SPEC stg3 6puck clutch, TRD springs. Autometer gauges, PCP reverse indiglo gauges. P/P head,Intake, 17" SSR repl, Kaminari front lip and sides.338whp/272lbs tq at 18psi
FOR SALE! email: [email protected]
http://members.cardomain.com/1quick2
Old 04-01-2004, 09:15 AM
Re: Clear Corner ?'s For 03 Tib
I also wanted to add....I seen a tib with a carbon fiber lip. Does anyone know where to get this, and I also want some nice sideskirts that arent too overkill.
Old 04-01-2004, 09:55 AM
tibby01 tibby01 is offline
well, i know you can actually make your own clear corners out of the stock ones for the 00-01 tibs. maybe its similiar.
get a long screwdriver and needle nose pliers. carefully crack the amber reflector off the clear casing. then break it apart into little chunks with the needle nose pliers and remove out of the bulb hole.
or maybe you can open up the whole headlight assembly to get to them. stick it in the oven on low, and slowly increase the temp until you can pull the glue apart.
Old 04-01-2004, 05:04 PM
nisco nisco is offline
Tib Guy
Send a message via AIM to nisco Send a message via MSN to nisco
www.newtiburon.com
itll have everything you need
Old 04-01-2004, 07:20 PM
Adam_Hunsicker's Avatar
Adam_Hunsicker Adam_Hunsicker is offline
I made my clear corners from the stock headlamp assembly....
Use a hot gun (or a hair dryer) to heat up the joint between the clear plastic and the rear section of the headlamp assembly
Take a razor blade and cut the adhesive that holds the two pieces together (do this by sliding the razor blade between the two pieces)
Once you've cut all the way around pry the two pieces apart with your hands. It helps to have a second person. You'll have to apply a great deal of pressure so don't think you're going to break it.
When you get the two pieces apart the orange lense inside will fall right out.
Using black RV silicone to seal the joint, press the two pieces back together and hold together with duct tape. Allow to dry for 4-6 before putting the headlamps back on your car. DON'T BE STINGY WITH THE SILICONE. If you don't get a good seal you WILL get moisture build up inside the headlamp assembly which not only will look nasty but can shorten the life of your bulbs.
Enjoy. For pictures of the end result see my profile.
Adam
Black '03 Tib, 2.0, Auto
Old 04-01-2004, 07:36 PM
Tib Guy
http://www.newtiburon.com/forums/showthread.php?t=41 <== link to a very good diy for this... and painting tips if you want to paint your headlights a color
Old 04-05-2004, 11:04 AM
portscan69's Avatar
portscan69 portscan69 is offline
Send a message via AIM to portscan69 Send a message via MSN to portscan69 Send a message via Yahoo to portscan69
Adams way works best.. saw it done and bout to have it done myself.. its a little hard to get the lens apart but with a little patience you can do it.
2003 Tiburon GT V6 6-Speed
clear corner lenses for a 95-99 cavy F/S JStumpalump150 Classifieds 20 10-01-2006 11:07 AM
clear corners lenses for 95-99 cavys JStumpalump150 Non-Performance 1 09-26-2006 02:53 PM
Honda Crx jdm corners for clear corners CRX-Crooks Classifieds 3 10-30-2005 03:14 PM
Clear Corner Lenses for Box Caprice (1980) Drboogie Caprice 0 06-27-2003 11:32 AM
Clear corner lenses for a '98 Rodeo SVTBlackLight01 Rodeo | Passport | MU 5 04-15-2003 07:56 AM
