Go Back   Automotive Forums Car Chat > Nissan > Primera | G20 > General
General news, articles, other.
Old 12-21-2003, 06:30 AM
jvisconti jvisconti is offline
Post Trans problem
Repeated 5th gear problems at 200K mi
I have been told by 2 different trans shops that it is common to have a problem with 5th gear in G20's. The car was fine for the first 176K and then the problems started. When in 5th, the car pops out of gear.
Does anyone know about this? What have you done to resolve it?
My car runs awesome and I want to keep it. AAMCO fixed the clutch and then the 5th gear went.
Old 12-22-2003, 02:16 AM
md_emory md_emory is offline
ask that in g20.net if you want. I am not sure what is going on.
Old 02-13-2004, 10:04 AM
G202Go G202Go is offline
It's a common problem with early SR20 powered 5 speeds. G20.net might still be down so you might try http://www/sr20forum.com/
Some people get a later model 95-96 G20 transmission to fix it and some people go with a 200SX SE-R transmission with limited slip. In that case, you'd have to swap out the driver's side halfshaft with one from a G20t. Having yours repaired might work too but there are lots of expensive parts to replace and even then, you're at the mercy of the mechanics expertise.
Old 03-14-2004, 05:58 PM
MattBG20t MattBG20t is offline
Re: Trans problem
Yeah 5th gear popout is a common problem. Go to www.jgycustoms.com, they sell a kit to fix it.
97 4L60E Trans problem mavbeacon Silverado 9 10-07-2012 01:28 PM
Trans Problem? Andrew S CR-V 0 02-17-2010 12:48 PM
95 Towncar trans problems....help!!!! speeddemon_09 Town Car 4 09-20-2009 11:20 AM
F-100 with a 86 255 T-Bird engine and trans HELP Trans Problem TunerTim F Series 2 10-28-2006 10:53 AM
