Old 04-23-2010, 08:18 PM
mavbeacon mavbeacon is offline
97 4L60E Trans problem
97 Silverado - 5.7 with 4l60e trans. truck will not shift into 2nd gear while driving. stays in first gear until rpm are high and shifts into 3rd. under hard acceleration will stay in 1st until let off gas then shift into 3rd. manual shifting results in same, no 2nd gear until selector is moved into 3rd then shifts into 3rd. havent got any trans codes, fluid change netted no change in performance, fluid was pretty dirty but didnt smell burned, and there were no metal shavings in pan. any assistance would be greatly appreciated
Old 04-24-2010, 12:54 AM
transman618 transman618 is offline
Re: 97 4L60E Trans problem
Do you have reverse??
Also, will it shift into overdrive after it hits third??
transman
GM MASTER TECHNICIAN
SR. TRANSMISSION BUILDER
Old 04-25-2010, 03:57 AM
Yes it has reverse and it is shifting into od
Old 04-25-2010, 09:02 AM
turbinebalu turbinebalu is offline
you might need to hone out your valve body but first check to see if you have a shift kit in it
Old 04-25-2010, 11:22 PM
What I would do next is have the computer scanned. A tech needs to drive it with the scanner attached to see whether 2nd gear is being commanded by the computer. If you have 2nd command then I would pull the band servo next and examine it. Since you do have overdrive, we can assume that the band is ok.
transman
Old 04-27-2010, 05:14 PM
pgun67 pgun67 is offline
That's a cute picture of your little girl. Those smiles are the reason we work hard and bust our butts to provide for them. They are worth it.
PGun67
Austin, TX
2000 Silverado and a 2008 Silverado
Old 10-14-2010, 01:55 PM
RoryThornton RoryThornton is offline
Thumbs up Re: 97 4L60E Trans problem
If you have not yet solved your problem, In your 4l60e there are a number of eletronic solinoids one of these is a 2/3 shift solinoid this is an easy and cheap fix if doing it yourself. as i have done this repair on my 97 k1500 z71, Good luck and let me know how you made out.
Old 11-04-2010, 11:09 PM
dorfboy dorfboy is offline
Send a message via ICQ to dorfboy Send a message via Yahoo to dorfboy
You can get the shift solenoids pretty cheap, but also you may want to check some fuses. I have experienced this problem before and there is a Trans fuse in the driver's side fuse panel. The access door is on the side of the dash right when you open the door. I think it is like number 21 or 22.
Old 01-12-2011, 12:09 AM
Transmission Guy Transmission Guy is offline
Did you change the filter? This would be the first place I would start, if you did not do that when you were changing the fluid.
If you have done this find a shop with a scanner that can pull live data on your electronics. this will tell you for sure if it is the electrical
J Franciamore
www.transmissionkingatx.com
Old 10-07-2012, 01:28 PM
riddle64 riddle64 is offline
my 4l60e tranny is slipping have to rev to even get to move help
Tags
4l60e , chevy , problem , transmission , truck
