Go Back   Automotive Forums Car Chat > GMC > Yukon
Old 12-19-2003, 08:23 AM
bambislayer40 bambislayer40 is offline
Send a message via AIM to bambislayer40 Send a message via Yahoo to bambislayer40
Unhappy 4-wheel high not working!
i have a 99' gmc suburban with four wheel drive. my 4wheel low works fine, but if i try to go into 4 wheel high the light lights up but it doesnt engage and i end up with just staying in two wheel...any suggestions?
Old 03-01-2004, 06:25 PM
95yukon 95yukon is offline
Send a message via AIM to 95yukon
Re: 4-wheel high not working!
i had the same problem almost exactly...you might want to take a closer look at your 4-lo. i thought mine was working too because it was geared lower but the front tires still wouldn't spin. its probably your 4x4 ACTUATOR...i replaced mine for $110 at the dealership and it worked fine...it only takes a couple minutes to install (unplug one wire and unscrew the actuator...then screw the new one back in and plug it in) its a cylinder that sticks out of your front differential and its about 2 inches in diameter and maybe 4 inches long...good luck
4 wheel high not working gpn50 F Series 0 08-25-2009 09:52 PM
2001 Durango 4 Wheel Drive not working tomjames Durango 1 04-29-2005 12:16 AM
4X4 control panel lights not working 4 wheel drive not working french69ssrs S-10 1 12-28-2004 05:25 PM
4 wheel drive not working dlw_1240 Cherokee 4 12-14-2004 07:24 PM
4 wheel low not working horsepwr16 Blazer 0 12-01-2004 10:19 AM
