i just recently bought a 86 cherokee and the 4 wheel drive is not working you can put it in 4 wheel drive and the front drive shaft will turn but the front wheels wont turn. Please help.
sounds to me like the hubs are not engaging, I think they are vacuum acuated! I am sure someone here can help you out!
Re: 4 wheel drive not working
More than likely your jeep has the axle disconnect motor on the front axle. Look on the axle on the passenger side there should be a small motor housing with a vacuum disc with vacuum lines. There is a slide collar that shifts the 2 front axle shafts together. If you want email me [email protected] I can send you picture of how you can convert to a manual engagement cost about $ 20-25 Dale
Re: Re: 4 wheel drive not working
neat thing about the manual engagement, you can use low range in two wheel! Great for using low range on pavement!
