Go Back   Automotive Forums Car Chat > Racing > Street Racing
Old 12-17-2003, 01:02 AM
eps's Avatar
eps eps is offline
Semi-automatic?
In the car I drive, my dad’s ’02 Cadillac Elderado, it has 1-2-3-D gears. My dad and I always just use D when driving, but I was wonder what the 1-2-3 are for. Can I start off in 1, and then shift to 2nd, then 3rd, just like in a manual? If that’s what they are for, how do I shift? Do I just shift while pressing on the gas, or do I have to let off? If so, just a little bit, or totally?
I didn’t want to try any of this on his car, because if I ruined it he would be furious!
Old 12-17-2003, 10:43 AM
topgear00's Avatar
topgear00 topgear00 is offline
Send a message via AIM to topgear00
Re: Semi-automatic?
You got it right. You can start in 1 and go up to D, and you don't have to back off. Some people feel it gives you better acceleration and control over power, although I'm not really so sure. I also don't know if it harms the transmission and drivetrain any, which it might, since it isn't intended to do that.
Old 12-17-2003, 02:17 PM
Polygon's Avatar
Polygon Polygon is offline
The Red Baron
Send a message via MSN to Polygon Send a message via Skype™ to Polygon
Yes you can nail the gas and shift through the gears. The problem is that it is still controlled by the computer. You might shift up or down and the car will not respond until a certain RPM is reached. The computer will protect you from destroying the transmission. The difference you will see will be unnoticeable. If you want to race buy a car with a manual.
Just don't do and neutral drops or power braking.
Old 12-18-2003, 01:10 AM
ColeIketani's Avatar
ColeIketani ColeIketani is offline
Send a message via AIM to ColeIketani
Re: Semi-automatic?
Well I do have one tactic that works with Automatic Drivers. Once you get up to 3000+ RPM a quick tap off the gas will have the car shift into the next gear instead of just waiting for the car to redline and then shift to the next gear. This works very well for shifting up, but for downshifting there is more of a problem. My car has shifttronic so I can downshift smoother, but it isn't as fast as a manual most of the time. Left foot braking or quick brake/throttle movement will kill most of the unsteer in FWD car (At least in mine). (This isn't just a fable or folktale) But for right now I'm 6-1-3 for offical records so I can't complain.
2003 Hyundai Tiburon: Injen CAI, Mussa Single Exhaust, Sparco Four Point Harnesses, RRM Front and Rear Strut Bars, 22mm Rear sway bar, Shark Racing Pedals, Painted Rims.
Saving for: Either Big Brake Kit, lines etc, Tien Coilovers Sparco Speed Seat for driver side.
Old 12-20-2003, 01:24 AM
TatII TatII is offline
Re: Re: Semi-automatic?
alright if your racing. why would you want to shift the car when its just starting to reach its power band? if its for everyday driving and saving gas, then yes letting the foot off the gas is good for gas mileage. and for downshifts. all you gotta do is floor the car. and hte computer will see that your tryin to do a highway pass and it will kick down a gear.
303whp stock internal KA-T
94 Acura NSX
Best E.T. 13.559
Best Trap speed 107.62 mph
Old 12-20-2003, 06:02 AM
fatninja19 fatninja19 is offline
Send a message via AIM to fatninja19
How does this understeer elimination stuff have to do with shifring??
when in doubt, throttle.
Rant: semi logic semi venting Ace$nyper Stress Release 12 09-23-2005 10:07 PM
Semi-completed 911GT3 awaken1973 WIP - Street 16 01-13-2002 01:28 AM
max nos shot on a semi-stock engine blatch '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 6 01-06-2002 08:15 PM
JAPAN DUNLOP formula R semi slicks for road or street races awesome GOKOOL Classifieds 0 10-24-2001 12:53 AM
Best '96 G20 semi-stock suspension? cathandler Suspension 4 04-26-2001 11:54 AM
