Old 12-16-2003, 04:23 PM
SniperX13's Avatar
SniperX13 SniperX13 is offline
Send a message via Yahoo to SniperX13
clear coat question
Ok, I am currently working on the Porsche GT1 and I painted it the flat black because I have to paint in my apartment since its winter, and the flat black dries in like 5 minutes. My question is, should I apply a few coats of high gloss top coat BEFORE I start applying the decals, or to put the decals on the flat black, then top coat it. I am worried about the edges showing on the decals. all help is appreciated. thanks.
"Who are we to judge those, when we ourselves are afraid to be judged."
Old 12-16-2003, 04:56 PM
malsheem's Avatar
malsheem malsheem is offline
20 inches and growing ...
Re: clear coat question
To my knowledge, decals like a nice glossy surface to stick to. You'd probably have problems getting them to adhere nicely to the flat black. Put the gloss coat on.
-Joe
www.quietrage.com
CWest R34 Skyline GT-R
Old 12-16-2003, 05:35 PM
dag65's Avatar
dag65 dag65 is offline
Send a message via Yahoo to dag65
Re: Re: clear coat question
I agree, I learned the hard way and put decals on a flat paint job and they did not stay on
Old 12-16-2003, 07:32 PM
willimo willimo is offline
Sweet, sweet tiny Hondas.
Besides not staying on, the edges will silver and it will look bad. You really need a glossy surface to apply them to.
Old 12-16-2003, 08:56 PM
p9o1r1sche's Avatar
p9o1r1sche p9o1r1sche is offline
Registered User
The way to do it right is to paint it glossy black first, then put on decals, then spray on dull coat.
Old 12-16-2003, 09:17 PM
86_SR5's Avatar
86_SR5 86_SR5 is offline
On the contrary, I have better luck applying decals to flat surfaces, especially flat black. They usually run off the glossy surfaces, and dont stick well for me.
RIP Indian Larry RIP
April 28th, 1949 - August 30th 2004
IN GOD WE TRUST
VENGEANCE IS MINE
SAYETH THE LORD
NO FEAR
Old 12-16-2003, 09:25 PM
dag65's Avatar
Re: Re: Re: clear coat question
Thats odd, they are designed for a smooth shiny surface, a smooth shiny surface provides the needed cohesion for them to stick . Flat paints don't provide this. If you are having your decals slide off the car I suggest you are using way too much water or letting them soak so long that all that all the adhesive is gone.
I would have to agree that if you want decals on flat black , go gloss first and then use a matte clear coat over them
Old 12-16-2003, 09:27 PM
86_SR5's Avatar
Re: Re: Re: Re: clear coat question
I usually leave them in the water until the whole thing comes off the paper, so it doesn't crumple.
IN GOD WE TRUST
VENGEANCE IS MINE
SAYETH THE LORD
NO FEAR
Old 12-16-2003, 09:31 PM
p9o1r1sche's Avatar
Registered User
whoa! - too much soak time. If they come off in the water dish, most of the adhesive comes off also. Just soak them until they slide off the paper backing.
Old 12-16-2003, 09:32 PM
dag65's Avatar
Re: Re: Re: Re: Re: clear coat question
Ahh as I suspected. By that time most of the adhesive has come off, does the water look a little milky??I usually let them soak only long enough to slide around on the backing.
I slide it to one edge, carefully place that edge on the correct spot on the car and gently slide the paper away. You can also use a small soft brush to help move it around a bit.
Old 12-17-2003, 03:50 PM
86_SR5's Avatar
Re: Re: Re: Re: Re: Re: clear coat question
No, it usually don't, but sometimes it does. Thanks for the tip, I'll be sure to use it.
IN GOD WE TRUST
VENGEANCE IS MINE
SAYETH THE LORD
NO FEAR
Decals - Clear coat & Sanding grit Zman007 Auto Collision Network 1 12-24-2010 07:52 AM
Clear coat question AstroRide44 Car Modeling 9 12-15-2003 12:33 AM
clear coat question theT Car Modeling 7 09-27-2003 02:00 PM
tamiya clear coat question theT Car Modeling 9 09-09-2003 07:24 AM
Clear coat question awaken1973 Car Modeling 0 01-29-2002 06:19 AM
