Old 12-16-2003, 12:54 PM
ballinhb ballinhb is offline
b16a mounting problems
i just put a b16a into my 1990 honda civic si and the bottom of my motor seems to be sitting to far forward and it is putting an angle on my axles so when i turn the axle is at its extreme angle no matter how much or little i turn so it makes a realy bad clicking noise . i was just wondering if anyone has seen this before or knows what i can do to make the bottom of the engine to go back a little bit .. i used place acing motor mounts to if that helps
Old 12-16-2003, 01:07 PM
Hybrid1990crx's Avatar
Re: b16a mounting problems
What brand of mounts did you get? I heard that some of the cheapies from ebay don't always work all that great.
Or maybe its cause you are using the civic half shaft? You should be using the integra shaft, to avoid the clicking.
Old 12-16-2003, 07:07 PM
i am using the place racing motor mounts
Old 12-17-2003, 03:01 PM
Hmmm. Make sure they are welded right. If you have access to another set of mounts, compare them to yours.
B16A Mounts fiberglasscivic '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 4 11-01-2006 07:05 PM
b16a mounts aemfun '88 - '91 Civic | CRX | Wagon | Shuttlee 8 11-04-2002 02:34 PM
B16A Starting problems shatshadarach Engineering/ Technical 6 07-23-2002 07:09 PM
B16A Starting problems shatshadarach '88 - '91 Civic | CRX | Wagon | Shuttlee 0 07-17-2002 12:17 AM
b16a mounts shatshadarach '71-'87 Civic | CRX 10 03-21-2002 02:05 AM
