Old 10-31-2006, 04:37 PM
fiberglasscivic's Avatar
fiberglasscivic fiberglasscivic is offline
Send a message via AIM to fiberglasscivic Send a message via Yahoo to fiberglasscivic
B16A Mounts
Anybody know who makes good mount kits for a B16A Swap and are they bolt on or would I need to weld anything?
AF COMMUNITY GUIDELINES
Old 10-31-2006, 09:27 PM
AudioGuy93DelSol's Avatar
AudioGuy93DelSol AudioGuy93DelSol is offline
NA is Best!
Send a message via AIM to AudioGuy93DelSol
Re: B16A Mounts
Hasport and Innovative Mounts. They are all bolt-on applications.
Oil leak? What oil leak? That puddle under the car is just sweat from all that horsepower.
"How many NASCAR passes is that worth? 500?" (Schumacher passing Raikkonen)
Emily is amazing, and she messed with my sig AGAIN!
Old 11-01-2006, 01:39 PM
CivicSpoon's Avatar
CivicSpoon CivicSpoon is offline
There is no Spoon
Re: B16A Mounts
You chould just use the b-series drivers side mount (and bracket that attaches to the block), a rear bracket from a usdm B-series, and the rest are D-series mounts (including the rear). Energy Suspension makes replacement bushings, if your old ones are bad. And that might end up being less expensive than buying a whole mount kit. Just something you might want to think about.
Old 11-01-2006, 06:47 PM
Greenblurr93's Avatar
Greenblurr93 Greenblurr93 is offline
Kind of a Big Deal
Send a message via MSN to Greenblurr93
Re: B16A Mounts
if you do use the stock mounts... but want a stiffer mount and dont want to spend the money buy some 3M Window Weld (its polyurethane) and tape one side shut and fill the mount..if u do a search there are a couple threads somewhere with a How-To
Old 11-01-2006, 07:05 PM
Re: B16A Mounts
There's no using the stock mount's, I don't have all of them and the ones I do have are shot. I'll look into what you said civicspoon. Is the USDM B series mount on the driver side only the top with the bracket or is it only the bracket and what about the lower mount?
