Old 12-16-2003, 09:11 AM
dligg14865 dligg14865 is offline
Front Wheel Speed Sensors
I am having a malfunction with my anti-lock brake system. When braking the front wheel speed sensors fall out of sequence causing a false signal to the ABS Pump. I am looking for a way to get around this without replacing both front hub bearings which would be almost a $1000.00.
I've heard that there is a way to disable this but haven't had any luck in my research. If you have any information please respond...thanks in advance!
can the front wheel speed sensors be reached menaztricks Cavalier 2 08-22-2006 03:36 PM
How to repalce my right front wheel speed sensor for 95 Camry satexasuser Camry/Camry Hybrid/Vista 2 11-07-2004 07:44 PM
Testing front wheel speed sensors 1996 scholzee Blazer 2 11-03-2004 05:05 AM
front wheel speed sensors tjh109 Yukon 2 09-19-2004 06:56 AM
Front Wheel Speed Sensor mote01 Alero 3 02-22-2004 09:54 PM
