Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 10-15-2004, 11:46 AM
satexasuser satexasuser is offline
How to repalce my right front wheel speed sensor for 95 Camry
Okay, I want to remove my right front wheel speed sensor but I'm not sure what it looks like or where on the right side it's located. Does anyone have any good links to a how to fix it? or links to pictures of where or what the sensor looks like?
Old 10-15-2004, 03:54 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: How to repalce my right front wheel speed sensor for 95 Camry
It looks like a probe attached to a cable.
The speed sensor is mounted almost exactly opposite the disc brake caliper, inboard of the steering knuckle. It has a cable running up from the sensor above the half-shaft/CV boot.
To remove it, you remove the fender liner, disconnect the connector, remove the three clamp bolts (45 in-lbs) holding the sensor harness to the body and the shock absorber, and then remove the sensor from the steering knuckle (69 in-lbs). Installation is reverse.
Old 11-07-2004, 08:44 PM
vroom vroom is offline
I have been trying to replace a speed sensor in the rear right wheel of my 96 Toyota Camry. Removed all the bolts holding the sensor; however, can't remove the sensor itself as it appears to be tightly held in the socket. Press fit?? In the process, I hava broken the top half of the old sensor. The other half does not come out of the socket even after applying HD40. A struggle indeed. Any help??
These sensors are so expensive... I do not know why??
