Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 09-15-2003, 10:37 PM
gurup gurup is offline
Unhappy HELP !! Hard start and stalling with Camry - Only when hot !!
Hi,
I have an 89 Camry with 130K on it.I have a weird problem of late:
I start the car in the morning - starts fine and runs great. Then I park it under sun. Then in the noon, I try to start it, would start fine and run OK until I have to stop at a light. It DOESNOT stall when idling at the light. But ONCE I PRESS THE GAS PEDAL when the light turns green, it hesitates and stalls. Then I have hard time restarting it. It will crank, but not start. Even if it does, it will stutter and die immediately. Finally it will start after 10-15 attempts, giving out a lot of black smoke in the process. This happens at every traffic light from that point onwards, sometimes restarting immediately and sometimes taking time. It even stalls when pressing the gas after taking a turn. The same thing continues all through the day. In the evenings when the air is cool, it starts right away and runs just fine !!
I just got the fuel-filter replaced and the dealer says the ISC has a high
resistance. It will cost me $500 to replace it. :-(
Any clues on what may be wrong here ??
I found somewhere on the internet that Engine Coolant Temp Sensor affects ISC operation and since this problem seems to happen only when hot, could it be the culprit ?
Any help is greatly appreciated..
Old 11-18-2003, 05:31 PM
rydepowder rydepowder is offline
re: stalling
i'm having the same problem only it occurs in high humidiy and after rain. did you figure out what was wrong?
Old 11-22-2003, 03:37 PM
ChewToy's Avatar
ChewToy ChewToy is offline
Send a message via AIM to ChewToy
I recently put on a used distributor and that seems to have fixed my stalling problem (I pray) it was very similar to yours. I'm still having starting issues and it seems it can be cold or hot doesn't really matter apparently. Turns over (no clicking) but almost seems it's not getting fuel or something. After a few tries it fires up but I have to give it gas to keep it running or else it dies immediately
Old 12-13-2003, 09:54 PM
dm213020216 dm213020216 is offline
Send a message via Yahoo to dm213020216
Re: re: stalling
I have the same problem in high humity - like before rain, and during the rain. No problems on sunny days. Same stall symptom - idles fine at a light, then coughs and dies when you hit the accelerator.
I tried a new distributor cap and wires. Didn't help.
Old 12-15-2003, 01:18 AM
fhs8860 fhs8860 is offline
Re: HELP !! Hard start and stalling with Camry - Only when hot !!
: Hello everyone
: I have a 89 camry. It takes a lot of cranking to start the car when the engine is COLD but starts on the first try when hot. any idea what could be the problem.
: Thanks
: Faisal
