Old 12-14-2003, 06:05 PM
pawleysissc pawleysissc is offline
1996 taurus wagon ELECTRICAL PROBLEM!
96 taurus wagon ......... car is on and running smooth, the radio is on and working fine, until i shift out of park. when in reverse, or drive, the radio display is on,... but no sound.... neutral and park, all power equiptment (windows, door locks, etc.) work just fine... also while driving the radio sometimes works, but not the power antenna, and or the windows wont work (but just for several seconds) a friend advised me who owned a ford truck that he had a similar problem and said to replace the fuses(both under the hood and under the dash that are directly linked to this problem.......sometimes while driving and everything is going haywire, a rapid clicking noise is heard from the interior fuse box. (sounds like one of the relays doesnt it?) now what gives? a short? neutral safety switch? -(car wont start in drive or reverse).......... other then taking it in for a diagnostic, what else can i do, other then look for corosion on the connections? could someone please help me, i sure would appreciate it.
Old 12-15-2003, 04:15 AM
pctoyou pctoyou is offline
Re: 1996 taurus wagon ELECTRICAL PROBLEM!
Same thing happened on My taurus, turned out to be a switch on the transmission that had failed! Go figure! Call your local dealership, they should be able to get the part relatively cheap!
Old 12-15-2003, 08:33 AM
Re: Re: 1996 taurus wagon ELECTRICAL PROBLEM!
thanks for the quick reply, do you know what the name of the switch is?
Old 12-26-2003, 09:56 AM
rk3442 rk3442 is offline
I have a 1996 Taurus GL and you just name my problem exactly. Same thing...in park everything works fine. In drive and reverse there is no sound from radio, windows don't work, rear defroster doesn't work, intermittant wipers don't work and same clicking sound under dash. Did you ever find out what the problem was? I really hate to take it to the dealer if it's a quick fix.
Old 02-11-2004, 02:22 PM
mrenfro mrenfro is offline
Hey ya'll,
This is awesome! I followed this information and the part on the transmission is the transmission range sensor. After replacing that, the problem is fixed.
Thanks!
Old 11-29-2004, 09:35 PM
shivan shivan is offline
THANK YOU VERY MUCH ! this saved me time and money!
1997 Taurus wagon -alternator? Greeneyes_2006 Taurus | Taurus Wagon 6 04-12-2010 01:41 PM
Electrical Problems...... GaryCifers Corsica 6 01-13-2010 04:08 AM
1996 Taurus wagon starting problems mike lofgren Taurus | Taurus Wagon 6 04-07-2008 12:38 PM
1996 Taurus Wagon Electrical? FordOwner51 Taurus | Taurus Wagon 14 11-17-2007 04:34 PM
2001 taurus wagon electrical problem blow fuses thewifestaurus Taurus | Taurus Wagon 3 05-10-2005 09:59 PM
