Old 05-03-2005, 11:59 PM
thewifestaurus thewifestaurus is offline
2001 taurus wagon electrical problem blow fuses
we have a 2001 wagon and it keeps blowing the powerwindow.pl,pantenna,batterysaver,interiorlight fuse.I have disconnected the pwr antenna and metered the wires bit it has 4 wires two red i figure are pwr for going up and down,a black which is groun but there is a green wire which is also going to ground.I cant find out where the grreen wire is suppose to go any suggestions and or leads to this snag?
Old 05-04-2005, 02:23 AM
KimMG KimMG is offline
AF - Advisor
Re: 2001 taurus wagon electrical problem blow fuses
Do you have a wiring diagram?
Old 05-04-2005, 09:26 PM
no i dont have a wiring diagram.
Old 05-10-2005, 09:59 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
According to the wiring diagram for my 1998, the dark green wire goes to a 5 amp fuse (circuit 22?) that is hot at all times. There is a red/black wire that goes to a 5 amp fuse (circuit 8?) which is hot in START. The black wire goes to ground, and the red/pink wire goes to the rear control unit pin 10 of connector C478.
With the power antenna unplugged, do you still have problems with the fuse blowing?
-Rod
