Go Back   Automotive Forums Car Chat > Nissan > 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX
Old 12-12-2003, 07:18 PM
jwilliamf jwilliamf is offline
Drilled/slotted rotors with abs
How come on ebay all the drilled and slotted rotors say, "with non abs models only?" I know the abs obviously is the reason, but why. Also can you get performance rotors for ABS?
Old 12-15-2003, 06:58 PM
Come On, One Of You 240sx Junkies Has To Know What Up!!!!
Old 12-16-2003, 03:15 PM
gunluvS14's Avatar
gunluvS14 gunluvS14 is offline
Re: Drilled/slotted rotors with abs
the non abs rotor is slight smaller in diameter and little bit narrower... but as long as the ABS sensor is in place, I don't see why it wouldn't work.
but if I am you I will try to get the correct application. You sure they didn't list any of them. Many place sells for both ABS and non-ABs application. Also S13 and S14 has same brakes unit, so if they only listed 91-94 or only 95 above either way around, it will works.
PM if I confused you and want more help.
good luck
Old 12-17-2003, 09:35 AM
gunluvS14's Avatar
oh yea, just a thought.. I wouldn't depends my shopping on ebay.
here are few great shop for 240sx.
http://www.enjukuracing.com/
http://www.splparts.com/
http://www.projectsilvia.com/
http://www.phase2motortrend.com/
http://www.tougefactory.com/
http://www.jspec.com/
if u having trouble to find abs rotor for yours.. go to www.tougefactory.com, they carry them. And remember S13 and S14 are identical unit.
Old 12-17-2003, 01:44 PM
spitz7985 spitz7985 is offline
Send a message via AIM to spitz7985
some s14s came in 5 lug
Old 12-17-2003, 01:53 PM
gunluvS14's Avatar
oh I am sorry, i forgot some S14 has 5 lugs.. thanks for pointing that out.
well, here how about http://www.irotors.com/
Negative experience with Brembo cross drilled/slotted rotors from ebay? toicy4ya Off-Topic 7 07-18-2005 07:29 AM
Slotted Rotors VS. Drilled Slotted Rotors marx7 Engineering/ Technical 4 01-22-2004 09:03 AM
Crossed drilled/slotted rotors. kris Engineering/ Technical 14 01-26-2002 03:31 PM
FS: 4th gen Cattman Y-Pipe & Brembo X-Drilled/Slotted Rotors black019 Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 0 11-26-2001 03:09 PM
