| Off-Topic Talk about anything other than cars. |
Negative experience with Brembo cross drilled/slotted rotors from ebay?
Yes I know they're not authentic Brembo Crossdrilled/Slotted rotors. They're regular brembo rotors that have been drilled and slotted. My question is to those of you who have actually purchased them, what have your experiences been like?
Thanks
99 Eclipse Spyder GS |
Re: Negative experience with Brembo cross drilled/slotted rotors from ebay?
'92 3000gt SL Zoom Stage 1 Clutch Quote:
I purchased mine from www.turboimport.com. They were $239 for all 4 corners. I mated these with a set of Akibono ceramic pads.
I love them, they stop on a dime, no fade, shudder, or shaking. This will be a mod I do to every car I buy. What problems have you had? Did you install them so they rotate in the correct direction? Did you bed the breaks and break in the pads and rotors correctly? Did you replace the pads when you did the rotors?
![]() 1997 Spyder GS-T 5-Speed EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads |
Havent had any problems at all Spyderturbo, I havent installed mine's yet.
Do you have the exact same ones I got Brembo crossed drilled/slotted, I only see cross dimpled/slotted at www.turboimport.com? How is the pattern of the rotor suppose to go?
I went with the slotted/dimpled rotors because of the cracking issues with the crossdrilled.
I did a write up of the installation here: http://www.automotiveforums.com/vbul...d.php?t=397132
Thanks,
I had already printed it out. lol. I have the same concern with the cracking issue that's why I posted this thread to get some feedback of anyone who's actually running on cross drilled slotted rotors. I already purchased them and unfortunately there's no exchange/return policy.
I bought the slotted and cross-drilled rotors off of e-bay probably 2 years ago and have had no problems with them. I check them (at least I did when the car was running) every once in a while but have seen no cracks or warpage. I think the cracking problem is more common with just cross drilled where you have a considerably larger number of holes spaced closer together. I'll post a pic of my rotors if I remember (they are off the car right now)
I'm>everything |
yes please post the pics.
Thanks,
