Old 01-20-2004, 09:18 PM
marx7 marx7 is offline
Question Slotted Rotors VS. Drilled Slotted Rotors
I have heard that drilled and slotted rotors warp and wear quicker than non-drilled rotors. I know the drilled/slotted rotors perform better, but I am using these rotors on an Acura RL so I don't need performance. Does anyone know if this is true, or if the warping can be avoided (i.e. gentle braking for the first 1k mi)? I am looking at Brembo rotors and have heard different viewpoints on drilling and slotting rotors in terms of wearability. If anyone can clear this up, I would really appreciate it.
Old 01-22-2004, 03:47 AM
MustangRoadRacer's Avatar
MustangRoadRacer MustangRoadRacer is offline
Re: Slotted Rotors VS. Drilled Slotted Rotors
Contrary to popular opinion, they do not actually perform measurably better.
They are used to remove unsprung weight for handling purposes, and also for looks.
on the other hand, if you are not doing serious braking, you shouldn't have a problem with warping/cracking.
Best bet for a street-driven car is regular rotors. Larger rotors will help much more than drilled rotors of teh same size.
And the argument that slotted/drilled rotors romeve the gasses that build up from brake pads is old. Modern pads do not create nearly as much gas as old pads do, and it is no longer much of a concern.
Mustangs are nice, but I'd rather have one of these...
Old 01-22-2004, 05:57 AM
SaabJohan SaabJohan is offline
AP Racing are using J-slots because it reduce vibration.
Old 01-22-2004, 08:01 AM
Thanks for clearing that up. I really appreciate it.
Old 01-22-2004, 09:03 AM
johnnyBgood johnnyBgood is offline
Send a message via AIM to johnnyBgood
If you are going for the look, you can get slotted and dimpled. Drilled rotors tend to crack after 10K miles due to stress. Dimpled rotors are stronger than drilled and look just as nice.
