Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 12-12-2003, 07:06 PM
cclm3874 cclm3874 is offline
Unhappy brake light
i have a 2001 isuzu rodeo how can i change the brake light , i cannot seem to find how to even get in there
Old 12-13-2003, 09:04 AM
rodeo02 rodeo02 is offline
Locate the screws along the sides of the tail-lights- thru the "louvers". You have to pull the assembly out for lamp replacement. G/luck
Joel
Old 12-22-2003, 11:58 PM
MadDogMike MadDogMike is offline
More info, please
I need to replace my signal light. I have located & removed the screws in the louvers, but I still can't remove the tail light unit. What kills me is that I have done this once before, but now I can't remember how I did it!
Thanks for your help.
Old 12-27-2003, 08:36 AM
rodam rodam is offline
If I remember correctly.....
,,,you have to remove smaller screws that are attached to each section of light that needs to be replaced. Once the brake light assembly has been removed locate the smaller screws and remove them.
Old 12-27-2003, 08:13 PM
Re: If I remember correctly.....
Yeah, that's the problem...I can't seem to remove the tail light assembly. Are there more than the two screws in the louvers?
Old 12-28-2003, 08:45 AM
yeah, there's 4 screws to remove. 2 outboard, 2 inboard next to tailgate.
Old 03-26-2009, 10:23 PM
matxdad matxdad is offline
Re: brake light
2001 Rodeo Sport
Remove the 2 philips screws in the louver area.
Use flatblade screwdriver to gently pry the top of the light assembly away from the car - won't come completely out yet.
Use flatblade screwdriver to gently lift the light assembly from the bottom. This will expose a phillips screw at the bottom the the light assembly.
Pull out light assembly.
Twist/pull out brake light holder
Push/twist bulb to remove.
Reverse above to reinstall.
Old 03-26-2009, 10:43 PM
Cat Fuzz Cat Fuzz is offline
Re: brake light
Wow. Ancient thread.
2004 Sentra 1.8S-No brake lights?!? brynfrt05 Sentra | 200SX (USDM FWD) 11 06-08-2010 09:30 AM
1999 Passat - Changing Brake light bumpsetspikeki11 '97+ 0 03-09-2010 07:38 PM
emergency brake light comes on freakyfire05 ZX2 8 02-11-2010 10:19 AM
Brake Light Switch uspres2020 Escort 5 09-28-2009 12:11 AM
Brake lights problem corollastudent Corolla/Matrix/Voltz 1 07-20-2009 12:39 PM
