Old 12-12-2003, 01:23 AM
pumpkinhead pumpkinhead is offline
free car runs bad but still fun to drive!
I have a 89 std. hatchback w/200k I just picked up for free So heres the deal, once the engine runs up to temp it gets real doggy, if I get on the throttle to fast it bogs really bad unless I get it past about 1500-2000 and dump the clutch then it runs great all the way up in all gears. Also it won't hold a steady idle once its warm it really surges up and down. I put a timming light on it and it is retarding the timing when it acts up, I can make it act up if I snap the throttle fast off idle, if I go slower it revs up just fine. I have put in a new fuel filter, air filter, o2 sensor, distributor cap and rotor, spark plugs and I set the timing to the red mark (18 degrees?) The guy I got it from said it had been acting up for a while and he had new plug wires put on and it didn't help, they look new. I also checked the tps with my ohm meter and it is nice and steady through the whole motion allthough I don't now any spec for it, it still has the tamper proof screws holding it in. Any help would be great I have been searching for a place on the net like this for a long time and am glad I found this place. Thanks for any help or suggestions!
Old 12-12-2003, 01:41 AM
RedRacerCivic's Avatar
RedRacerCivic RedRacerCivic is offline
Send a message via AIM to RedRacerCivic
If you want to set the timing to TDC on the crank, You need to align the single white line on the crank pully with the groove on the lower timing belt cover. Maybe that can help you out on getting your car to run a little better, maybe the timing if off a little.
-1991 Civic Si (Sold)
-1990 Accord EX(Sold)
-2000 Civic Hatch
-1998 Lexus SC300
Click here to see my Shoe!
Old 12-12-2003, 01:56 AM
Re: free car runs bad but still fun to drive!
Any idea which notch is the white one? I was under the impression the center one of the three close together was the one I am supposed to use it looked kinda red under all the rust!
Old 12-12-2003, 02:44 AM
Autocratic_1st_Gen's Avatar
Autocratic_1st_Gen Autocratic_1st_Gen is offline
The TPS should be .5V closed and 4.5V at WOT I think.
i have a 91 Civic DX with 3x as much money in it as what i paid for it
i wish it was fast
here is my website
http://www.geocities.com/krustindumm/index.htm
Old 12-12-2003, 02:47 AM
It is at .7 at closed and 4.7 at wot.
Old 12-12-2003, 03:07 AM
cot's Avatar
cot cot is offline
i think the one you want is supposed to be red
you are supposed to set the timing at idle, and there's a jumper you need to short out to prevent the timing advance from affecting your setting.
Old 12-12-2003, 03:25 AM
thats the one with the yellow cap right?
Old 12-12-2003, 03:57 AM
cot's Avatar
cot cot is offline
yeah, that's the guy
http://www.automotiveforums.com/vbul...d.php?t=154489
Old 12-12-2003, 07:24 AM
johnb16a2's Avatar
johnb16a2 johnb16a2 is offline
Check some of your sensors like the coolant temp etc.
Old 12-12-2003, 12:39 PM
My check engine light has never came on (except when I turn the key on) anybody know how to check for codes? Anyone know what I should have for readings on coolant sensor or another sensor?
Old 12-12-2003, 02:03 PM
sastanley's Avatar
sastanley sastanley is offline
AF Premium User
Send a message via AIM to sastanley Send a message via Yahoo to sastanley
if the check engine light is only before start up in the "on" position, you shouldn't have any codes..the light will stay on or flash on later if you have codes..they way to check is the ECU (under the passenger side carpet) will blink if the engine light flashes at you.
One recommendation I have is to make sure you have good gas in the car (i.e. drive until almost empty and get good fresh gas from a reputable retailer) and reset the ECU. Do this by pulling the ECU fuse under the hood for 15-20 secs. Although you may not be throwing any codes, it is possible the ECU has some bad programs stored in it from the previous owner's driving habits, etc... Start the car after resetting the ECU and let it run for 20-30 minutes at idle to let the ECU re-map everything. Drive it nicely for a bit to let it get used to things and see how it runs. Obviously, make sure the timing, etc.. is set to stock settings before trying this.
Also, ECU codes for 4G's can be found in the "FAQ" thread at the top of this 88-91 Civic forum.
And if I screwed anything up above, I am sure peeps will correct me
Oh yeah - and welcome!!!
Get the
-Shawn
'91 Civic DX sedan
DOHC ZC, I,H,E, urethane bushings and mount inserts, rock chipped hood, some rust, stock steelies, nice comfy Integra seats, and the A/C works! What else could you want from an 18 year old car with 241,000 miles? Working on getting the Si tranny in now
Old 12-13-2003, 12:25 AM
BullShifter's Avatar
http://www.binghamtonlife.com/manual/2gsm/default.htm - that might help you with some of your questions.
Old 12-13-2003, 03:17 AM
I took it into the local garage to a guy I trust to get his opinion after I tried clearing ecu and letting idle a bit (did't make any difference) and he stuck his trusty screwdriver in the plug wire with it running and watched it spark while it was running and had me snap the throttle to make it act up and he said the spark looked really weak and he was pretty sure the coil was bad and recommended I replace it because he has seen simalar things on these motors and thats what it turned out to be. He only charged me $30 and that was including what I didn't pay him for diagnosing the last two cars I brought out to him. The parts stores want at least $75. I have no problem paying this much to fix it but I don't like to throw money away! Btw thanks for the input and the link to the manual! Any ideas of some other things to check before I try the coil? Also is there anthing I need to know before changing the coil?
Old 12-13-2003, 04:04 AM
V-K V-K is offline
Send a message via AIM to V-K
My engine acted pretty much the same way about a year ago. Replacing the coil made it run OH SO MUCH NICER. Idle was smooth and it stopped bogging down once I reached anywhere between 1000-1700RPM. I think at the time I had about 175K on it. I have the LX Sedan but I'm pretty sure we are running the same motor.
Old 12-13-2003, 04:13 AM
I am going to go buy a new coil in the morning and give it a try. Anything I should know before swapping it?
PROBLEM 3.1 car RUNNING BAD! triplerc Lumina 3 06-01-2006 07:02 AM
97 CV when temp goes up car runs BAD! Tony the TaxiMan Crown Victoria 1 04-16-2006 07:28 PM
engine light is on car runs fine but exhaust stinks jonnyhammer Escort 2 12-11-2004 12:55 AM
89' Delta 88: When it rains, car runs badly... 5LtrEtr Eighty Eight 2 03-14-2004 04:41 PM
