Old 11-17-2003, 11:55 PM
jkw1689 jkw1689 is offline
Send a message via AIM to jkw1689
Timing Light! Where it the check connector?
It tells me to short out the check connector, but I can not find it. The Haynes tells me to look on the back of my engine compartment and it will be on the left my EVCI tells me on the right. I am looking for a yellow rubber cap. I can not find this can anyone help me.
88 DX 1.5
I am just trying to set my timing.
Old 11-18-2003, 12:12 AM
BullShifter's Avatar
Re: Timing Light! Where it the check connector?
The connector should be under-hood left rear(d/s) or near the p/s footarea.
Edit:thinking of something else - but now the info is correct
Maybe this try it will be right
Old 11-18-2003, 12:41 AM
GTA's Avatar
GTA GTA is offline
Whee..
its circled in this pics.. near the driver side shock, best pic i had to show where it was.
AF Bay Area Crew
RIP Melt
2008 Mitsubishi Lancer Evolution GSR
2007 Toyota Prius
I <3 and miss my 4g
Old 11-18-2003, 12:43 AM
cot's Avatar
cot cot is offline
In my 91, that connector is under the dash on the passenger side, all the way over near the door - this is what the picture from the factory service manual jackassi posted shows
however, a quick look in chilton says that for 88-89 models, it is in the engine compartment where you are looking, so it's not the same
the text is
"Remove the YEL rubber cap from the ignition timing adjusting connector. This is located at the rear of the engine compartment on 1988-89 models"
"Connect a jumper between the BRN and GRN/WHT terminals of the connector"
For what it's worth, my connector had no cap and i identified it by the wire color as given above. It was bundled with some other wires as well.
Old 11-18-2003, 12:49 AM
Hey I have looked all under the passenger side floor board and I can't see a yellow rubber cap.
Old 11-18-2003, 12:55 AM
cot's Avatar
cot cot is offline
your car is an 88, it won't be inside the passenger compartment!
It's under the hood, look at the picture that GTA posted
GTA's Avatar
GTA GTA is offline
Whee..
my car, the car i posted a pic of, is an 88 dx. it should be right where i circled. the sticker on the bottom of the hood (if stock hood still) would tell you where it is definetly.
AF Bay Area Crew
RIP Melt
2007 Toyota Prius
I <3 and miss my 4g
Old 11-18-2003, 12:59 AM
Well I looked at the pick and I do have something over there where the pic is marked, but how do I know it is the right thing. The VECI does say it is on the right, but it is not clearly marked?
Old 11-18-2003, 01:01 AM
GTA's Avatar
GTA GTA is offline
Whee..
its like the only thing over there. i lost the yellow cap for mine, maybe that happened to yours too..
AF Bay Area Crew
RIP Melt
2007 Toyota Prius
I <3 and miss my 4g
Old 11-18-2003, 01:03 AM
Re: Re: Timing Light! Where it the check connector?
Its the only connector in that area with nothing plugged into it - should be easy to find!
Old 11-18-2003, 01:05 AM
Alright that is probably it.
Now when I am shining the timing light I will be shining it down at the crankshaft pully? trying to get the timing marks to line up?
Old 11-18-2003, 01:08 AM
Here is how : http://www.binghamtonlife.com/manual...s/91-23-58.jpg - samething as in the 1st post
Old 11-18-2003, 01:13 AM
Well thanks Jackassi, and the rest of you too. I will try this out tomorrow.
Well Jackassi this is the final step I got my head back on and now I just have to get the timing back. I do get a little white smoke, but I hope that it will stop after the engine has been driven for a little while. I am adjusting the timing because I have no power at acceleration.
Old 11-18-2003, 01:25 AM
Whatever happened with the head problem? Did you end up replacing the head bolts?
If it doesn't stop smoking within 500 miles, I'd do another compression test & some other inspecting.
Old 11-18-2003, 01:32 AM
The head bolt are not the replacing kind. The only place I could find to buy them wanted to charge me $10 a bolt. I just re tapped and die the head. I had the head checked and they said it is good. I am not having the same problem now, so I just htink that my timing is off, since I took the ditributor cap off with out marking it.
Stupid Question... Where is the OBDII Connector? B4tm4n LS | MKZ 1 05-05-2008 10:09 PM
Where is the ALDL connector - 94 Buick Century My Name is Earl Century 1 02-16-2006 11:57 AM
What,Where is the DLC connector? LeSabre97mint LeSabre 2 10-02-2005 05:08 PM
1992 Eclipse Check Engine Light is on where is the service connector bratt Off-Topic 7 08-18-2005 10:50 PM
