Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 12-11-2003, 08:28 AM
Huffy76 Huffy76 is offline
clicking noise
Hi, I have a 94 Rodeo 4x4 and I am finding clicking/grinding noise at the rear of the truck. It only happens when I am turning and accelerating hard and to a lesser degree when i accelerate hard going straight. Also have notice that it happens when I use the "power" feature to gain more acceleration. No noise is heard during normal acceleration or at highway speed. Thanks for any info.
Aaron
Old 02-07-2004, 09:16 PM
danforth45's Avatar
danforth45 danforth45 is offline
Re: clicking noise
worn out u-joint? reach under your truck and grab the drive shaft. if it has alot of play, get it checked out. May also be worn out bearing in differential
Old 02-10-2004, 01:25 AM
silky4u's Avatar
silky4u silky4u is offline
My best guess would be a worn out diff bearing. This is due to the fact that under load (say when you press the gas) the helical cut of the ring and pinon gears try to force eachother apart. The bearing retains this outward movement of the gears, if this bearing was faulty this would not only make the bearing produce noise, it would either shift the pinion or ring gear out of their ideal contact pattern and make the grinding noise that you referred to.
I hate ALL people!
front clicking noise. wheel?? sohcd16 '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 3 10-24-2010 08:53 PM
Clicking Noise in Motor - Please help! Jpb1970 General Discussion 4 04-28-2010 11:38 PM
99 Sunfire GT 2.4L Twin Cam Auto--CLICKING NOISES FROM ENGINE BLOCK E. Frank Cavalier Problem Diagnosis 8 07-28-2009 06:25 PM
Max AC Clicking/Tach Problem tominton Cavalier Problem Diagnosis 1 07-09-2009 03:27 PM
2005 G5 - V6 Clicking Noise in engine donnap1957 G6 9 02-26-2009 07:44 PM
