Go Back   Automotive Forums Car Chat > Chevrolet > General Discussion
Old 04-27-2010, 12:45 PM
Jpb1970 Jpb1970 is offline
Clicking Noise in Motor - Please help!
Recently ran my truck MUCH too low on oil. It was not giving me warnings except every once in a while I would get a check oil level (like an idiot I didnt heed this warning)
I started to hear a clicking noise of what I assume is a lifter. I was only running 2 quarts of 6 capacity. I quickly added 4 quarts, drove it easy and had the oil changed after about a 15 mi drive back home. After this, I still hear the clicking noise. I thought maybe it would go away after it got pressure to fill the lifters back up, but so far no luck.
Did I do irrepairable damage possibly? What can be done at this point? What should I check and can anyone give me possible remedies or things to try.
Any help is greatly appreciated. Thanks
Old 04-28-2010, 11:55 AM
luxeryvic luxeryvic is offline
Re: Clicking Noise in Motor - Please help!
wat kinda engine?
Old 04-28-2010, 03:16 PM
j cAT j cAT is offline
I would try about 8OZ of marvel mystery oil in the crankcase ...If the problem goes away it was carbon in the lifters ...this occurs when you run low on oil , the oil temps rise to a very high level creating the carbon..
when the oil gets dark replace quickly, as carbon will greatly wear out your engine...
If the problem does not go away , then you most likely damaged the camshaft lobes or spun a crank bearing ...
since you have a oil consumption problem always carry a galllon container of oil with you....
Old 04-28-2010, 11:34 PM
Originally Posted by luxeryvic View Post
wat kinda engine?
Engine is a Chevy Vortec 8100
Thanks!!
Old 04-28-2010, 11:38 PM
Thanks! I am going to try the marvel mystery oil and hope it is carbon!
Tags
low , motor , noise , oil
