Old 07-18-2010, 01:44 PM
sohcd16 sohcd16 is offline
front clicking noise. wheel??
hey guys gotta question. i gotta 95 civic ex 5 speed and ive been hearing clicking noise latly when i accelerate past about 2k, and sometimes i hear a squeak when i turn when im going slow. also i hear a clicking when i brake at a certain pressure usually hard. what could it be? any1 please help me out. axles? cv joint, throttle body? mayb rim hitting clipper?? need new brake pads? i did just rotate my tires, but it didnt make this noise when i first did them 2 weeks ago. please help thank you.
Old 07-19-2010, 02:44 PM
jgr7 jgr7 is offline
Re: front clicking noise. wheel??
Make sure your lug nuts are tight.
jeff
Old 10-11-2010, 08:30 AM
deluxreverb deluxreverb is offline
If you hear the noise when you start off while accelerating with wheel turned it is most likely a CV joint. Have you checked the CV boots for wear? If quiet go elsewhere/
Old 10-24-2010, 08:53 PM
xquisnhr xquisnhr is offline
Honda Guru
Send a message via AIM to xquisnhr
yeah the clicking is definately your cv joints, just replace your axles and youll be fine, as for the squeek when turning at slow speeds, its most likely just your tires pulling across the pavement, ive heard this happen in a lot of vehicles especially if the wheels are turned all the way to one side... hope this helps
Tags
civic , clicking , front , noise , sohc
