Go Back   Automotive Forums Car Chat > Honda > Integra
Old 12-17-2001, 06:56 AM
TigRo TigRo is offline
Send a message via AIM to TigRo
Red face Wierd Noise at 3k-8k RPM
Usually When I high rev first and second gears, as well as the
downshift to 3rd and 4th, I hear this rattling noise.
The other post I read about my problem was about the heat shield rattling against the CAT, and I was wondering if anyone could tell me how that works, by cutting it or so.
The rattling noise is really annoying, because when I try to take off, the rattling begins, and I stop because I'm afraid something bad might happen, plus in parking garages when I try to set off alarms (MUAHAHA) i hear the echo of the rattle anyways
if anyone can help me with my problem then il be very thankful! haha
'97 GSR
JDM Integra TYPE-R
Front end Conversion
Zeal(Extreme) Sideskirts
Buddy Club Rear
Motegi 17"x7 gunmetal MR-7's
Toyo PROXIs
JDM Type-R Wing
JDM Type-R Carbon Fiber Hood
JDM Type-R one peice headlights
Apex'i Dunk Exhaust
AEM COLD AIR intake
H&R 1.7F 1.5R
PowerStop front Cross Drilled Rotors
Old 12-22-2001, 10:41 PM
cnycivic cnycivic is offline
Send a message via AIM to cnycivic
it could be a piece of yer cat converter .... thas ratteled into yer manifold ... this has happend to my friends del sol and it pissed him off for a very long time
Old 12-26-2001, 04:37 PM
CrazyCowPie CrazyCowPie is offline
Exclamation
Remove the heatshield...just don't drive over tall dry grass
8K...what were you doing at 8K...that's high reving there!
I came, I saw, I conquered!
Old 12-28-2001, 01:02 PM
95gsrvtek 95gsrvtek is offline
Send a message via AIM to 95gsrvtek
the problem u are hearing is mostlikely between 3k and 4k rpms.
that would be the headers. integra gsr's have had a problem with the a-pipe in the header cracking therefore a rattling sound comes around 3-4k rpms because thats where highest amount of pressure is let out of the engine and through the header.
so try the heat shield, but im almost positive its your header.
Old 12-28-2001, 07:58 PM
Hanguk87 Hanguk87 is offline
Well can you tell where the sound is actually COMING FROM? That is very important for us to know.
Old 02-11-2002, 04:28 PM
RunninSOHC RunninSOHC is offline
Banned
Rattling Noise
What You are hearing is the Catalytic Rattalitic. It is the result of a gutted Cat. I don't thing that there is a solution to this problem; just don't gut your CAT. I don't think it's worth it, and the long term damage you do to your lungs after reversing is not worth it; it stinks and destroys all signs of life on God's Earth. The Rattle is annoying. The car also smoke when you punch it. Leave the Catalytic Converter.......you need backpressure anyways espically if you want Turbo so stick with a CAT. The best practice to do to a Honda is to remove the resonator between the CAT and the muffler and put 2 1/4 piping instead of the 1 1/4 stock. On High end Honda Models (EX, VTEC, or Si or whatever else) the stock muffler will do just fine. I tested it and it makes no horsepower difference to take it off. Don't let your Honda make Catalytic Rattles.
Old 02-11-2002, 07:22 PM
what in god's name are you refering to? haha okay no offense but I have NO idea what all that meant. People are tellin me it is my headers and my heat shield, but you happen to tell me its my lungs and im going to die because its bad for the earth? haha okay
'97 GSR
JDM Integra TYPE-R
Buddy Club Rear
Toyo PROXIs
JDM Type-R Wing
Apex'i Dunk Exhaust
AEM COLD AIR intake
H&R 1.7F 1.5R
Old 02-12-2002, 02:05 PM
Speechless Speechless is offline
Is Tigro the politically correct version of Tigger's name?
Old 02-12-2002, 04:14 PM
hehe, I'm Speechless
'97 GSR
JDM Integra TYPE-R
Buddy Club Rear
Toyo PROXIs
JDM Type-R Wing
Apex'i Dunk Exhaust
AEM COLD AIR intake
H&R 1.7F 1.5R
Old 02-12-2002, 10:18 PM
Banned
Lightbulb Listen........
The symptoms of the noise you talked about were the perfect symptoms of Catalytic problems in a Honda. I am only telling you this because it may be something to do with the Cat. Gutted cat's or malfunctioned Cats on Hondas make a distinct rattle between 3 - 8 k RPM espically on downshifts. So you may have a catalytic to deal with....By the way do not ridicule me, I was only trying to help you and your slackin car
Old 02-13-2002, 04:57 PM
hehe, sorry bout that i think I misread your post. Anyways, thanks for your help again, i think il look in on it.
'97 GSR
JDM Integra TYPE-R
Buddy Club Rear
Toyo PROXIs
JDM Type-R Wing
Apex'i Dunk Exhaust
AEM COLD AIR intake
H&R 1.7F 1.5R
Old 07-07-2003, 06:57 PM
Vtec Vtec is offline
Its the stock header the plate inside rattles over time, if you don't want or have the money for an aftermarket header take it to an exhaust shop get them to drill one or even two holes right at the part of the header that looks like "Y" where it connects to the cat then weld the holes back closed to hold the shield still and stop rattling. My bro has a 94 GSR and had the same prob and thats what he did, worked like a charm.
EDIT: This thread is probably really old, and have the problem fixed a long time ago.
Old 07-07-2003, 09:01 PM
TheNotoriousMogg's Avatar
TheNotoriousMogg TheNotoriousMogg is offline
AF's #1 Bad Guy
Send a message via AIM to TheNotoriousMogg Send a message via Yahoo to TheNotoriousMogg
yah no shit dude...8k thats some fuckin up your engine type reving
Darrell
thegrumpysergeant.net
Old 07-21-2003, 06:30 PM
99GSR's Avatar
99GSR 99GSR is offline
My car makes that same noise too except my car makes it from 3,000 to 5,000 RPM or when i let go of the gas in low gear or downshift. I took off the heat shields but it kept on making the same noise. I don't think its your stock header or your CAT because i have aftermarket header and CAT and it still makes the noise anyway. I'm going to change my exhaust pipe to 2 1/4" to see if that'll stop making that damn noise.
Old 07-22-2003, 12:41 AM
Sid77 Sid77 is offline
Sounds stupid but the reason mine did it was because there was a very small rock in between the heat shield and the exaust pipe and it just kept rattleing away and the only reason i found it is because i started my car on a lift and listened for it and sure enuf there was the rock.
Extremely wierd hesitation at low rpm ChevCrazY C/K 1 09-23-2009 10:33 AM
whats the minimum is should go for a winch?2K 3K 8K? rob doggy dog Wrangler 2 06-13-2006 10:41 PM
wierd noise at 3000 rpms thecone137 Engineering/ Technical 1 05-19-2003 08:36 AM
Wierd noise after 2" drop???? Protek Tires and Wheels 6 09-20-2002 09:07 PM
Wierd noise after 2" drop???? Protek Accord/TSX/Accord Hybrid 10 03-26-2002 11:19 PM
