Old 03-25-2002, 03:45 PM
Protek's Avatar
Protek Protek is offline
Send a message via AIM to Protek
Question Wierd noise after 2" drop????
Ok, didnt happen at first but after a day or 2 it started up. Comming from the front passenger side. Now the noise is not constant, if I am accelerating, or braking I cannot hear it. However if I am just driving straight and either not stepping on the gas, or just keeping a constant speed I can hear it. It is a hard noise to discribe, its almost like somehting is rubbing however I does not appear that its possible. I have checked and there is clearance all the way around my tires. I am riding 16" x 7" rims on 205/50/16's I have turned the wheel all the way from side to side and it does not come close to anything as far as rubbing so It couldnt be the tires or rims. Also I had new axle shafts and cv boots and joints installed last year so I dont think that one of thoughs could have done bad again. I cehck the boots and they are still perfectly intact. What els should I check and how? How would I check the axle shaft to make sure that nothing is wrong with it??
92 accord by the way.
Make it idiot-proof and someone will make a better idiot.
Caution: I drive like you do.
Old 03-25-2002, 04:29 PM
brads94accord brads94accord is offline
Send a message via ICQ to brads94accord Send a message via AIM to brads94accord
try and explain what the sound sounds like a little better. my car mad a popping noise from the strut towers after i lowered mine. and it still does it but bearly. and my front passenger shock squeeks when i go down the road.
representin old school ph since april 2001, formerly UGAbrad94Accord
311 rules!
94 accord lx
16" konig reigns
3.25 inch drop on sprints and bec-techs.
clears all around, intake, custom rear section exhaust
farenheight plasma xenon headlights
click for my website
Old 03-25-2002, 04:37 PM
Protek's Avatar
Ok good point, First off the sound goes allong with the speed of the tire.
What I mean is if I am going fast the sound is faster like a rubbing grinding noise for every revolution of the tire. If I am creeping up to a stop at like 3-5 miles an hour its just a slow long rubbing gringing sound. I will try and get some audio of it but it may be to quiet to pickup on a recording.
Old 03-25-2002, 04:42 PM
well sounds like your tire is rubbing onsomething, check for control arms rubbing, and maybe the plastic liner in your fender well.
311 rules!
94 accord lx
16" konig reigns
Old 03-25-2002, 04:43 PM
oh yeah i almost forgot to ask, is your spring sitting on the perch right? if its not, your inner tire might be rubbing on the spring.
311 rules!
94 accord lx
16" konig reigns
Old 03-25-2002, 09:31 PM
Protek's Avatar
Well its deff. not my tires rubbing anything. I reached behind my wheel and ran my hand all the whay around the wheel so it is not touching anything. I did the same with the wheele cranked in bolth directions. Im pretty sure its sitting on the pearch right, but ill double check.
Old 03-25-2002, 10:58 PM
hondaman-iac's Avatar
hondaman-iac hondaman-iac is offline
Send a message via AIM to hondaman-iac Send a message via Yahoo to hondaman-iac
are u sure the cv boots are ok ? did u remove the steering knuckle when you installed the new suspension ? i had that nois a while ago and it was the rubber boot rubbing on the control arm lower balljoint. check that out
hondaman-iac @ HondaStyle
92 ACCORD LX -- powered by a blown F22A1
Current Mods:
*rear lower tiebar
*AEM CAI
*Koni Yellow Struts
*Ground Control coilovers
*Energy suspension bushing kit
*front upper strut bar
*rear upper strut bar
PureHonda member since April 2001
Old 03-26-2002, 01:58 PM
Protek's Avatar
Which rubber boot was rubbing??
Old 03-26-2002, 02:49 PM
the cv boot
Current Mods:
*rear lower tiebar
*AEM CAI
*Koni Yellow Struts
Old 03-26-2002, 02:52 PM
Protek's Avatar
So if it is the cv boot rubbing the control arm, how would I fix it? Would I just have to raise up the car a little like 1/4" or something?
Old 03-26-2002, 11:19 PM
do u have a camber kit on it ? on a second tough the ahle might be too long for the control arm. getting a camber kit should solve the problem. You did not get the noise the first 2 days because of the spring sagging, and the car lowered more during the sagging.
Current Mods:
*rear lower tiebar
*AEM CAI
*Koni Yellow Struts
