Old 12-10-2003, 02:24 PM
platter platter is offline
Unhappy Need help with this noise!
I have a 94 Chevy Suburban 4x4 2500 with 93k miles on it. I'm new so I don't know how to describe sounds in writing, but I'll try. I'm getting a "groany, with inconsistent little thumps, and sort of grindy" noise when going uphills. The travel uphill is sort of grindy as well.
On the level, I don't seem to notice it that much, but as soon as the vehicle goes on any sustained hill, the noise starts to be pretty audible and is quite apparent. After the hill, the noise subsides but comes back the moment the gas pedal is pressed and sort of goes away the moment the gas is taken off. This lasts for a long time.
It seems to be worse if the vehicle has been sitting out in the cold. The noise changes if the vehicle bounces due to undulations in the road.
I would really appreciate any help
Thanks
Old 12-11-2003, 01:32 AM
Boomyal Boomyal is offline
Re: Need help with this noise!
You might take a look at the front axle constant velocity joints. Check the boots for sure. If you've got any rips of tears that could be a problem. The joints could go bad even w/out ripped boots.
Old 12-11-2003, 06:22 AM
jfmctlaw jfmctlaw is offline
You say the noise only occurs going uphill so it sounds like a powertrain problem. I wouldn't suspect the front end unless it happened all the time. Have you checked all your fluid levels in the powertrain such as trans, and differentials (front and rear-but I doubt front).
Old 12-11-2003, 09:32 AM
Thanks for the reply...
I have checked the CV joints in the front for tears in the boots. They seem to be Ok. I have also checked transmission fluid and Diff fluild. Both seem ok.
Other suggestions most welcome
Old 12-11-2003, 09:45 AM
I think you are right, it seems to be a power train related issue since the noise is only evident when either accelerating or going up a hill. Could it be associated with bad universal joints or even a bad wheel bearing?
I need help with 350cid noise!! CoyCaller General Discussion 16 09-09-2007 02:41 AM
need help with tapping noise jmiles_97_lumina Lumina 3 03-11-2007 10:43 PM
need help with drivetrain noise on GSR Iceclaw Let's get Technical! 2 09-12-2005 09:38 PM
Need Help with whistle noise Stealth_LC 3000GT/Stealth 4 02-10-2005 11:22 PM
help!!!!! i need help with this supra envydisqbanpapi General 0 06-20-2004 12:58 AM
