Old 02-10-2005, 09:01 PM
Stealth_LC Stealth_LC is offline
Question Need Help with whistle noise
I have a 1991 dodge stealth sohc, I have been trying to find a whistle noise on my car. You can't hear it at idle. but when you drive it down the road and floor it you can hear it. I dunno if it is a vacuum line, or something else? anyone any ideas?
Old 02-10-2005, 09:10 PM
Thourun's Avatar
Thourun Thourun is offline
Send a message via AIM to Thourun
Re: Need Help with whistle noise
Belts?
1995 3000GT VR-4
Installed: ESP front precat eliminating downpipe, test pipe, RF-1008 K&N, Dejon tool Y pipe, 1G DSM BOV, MSD wires, Guted rear pre cat, ISSPRO EV Marine boost gauge, IPO MBC, EGR blockoffs, Palm m515 dataloger setup, NGK iridium plugs, SPEC stage II clutch 500ft/lb, 5300k HID plug and play setup.
Soon:Topline Engineering ground wires.
Old 02-10-2005, 09:46 PM
I have listened to the motor and don't think it would be belts. It sounds like it is more behind the intake or in that area. It still not as loud as what it is going down the road. I think its more in the intake area though. I dunno its really hard to find.
Old 02-10-2005, 10:46 PM
Twizted_3KGT's Avatar
Twizted_3KGT Twizted_3KGT is offline
Whistling is usually more of a vacuum leak than an intake leak...but check ur hoses, make sure that hose that plugs into the intake tube is plugged into it.
If you own a steth a scope you can really pinpoint it.
Old 02-10-2005, 11:22 PM
Igovert500's Avatar
blue + red light magnet
Pressure test it, there are instructions for building cheap pressure testers on www.stealth316.com, or you can get one from one of the members on 3si that makes and sells them.
That way you can pressurize everything without having the extra noise of the engine running.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
