Old 12-09-2003, 05:42 PM
pbcdb pbcdb is offline
Fuse for amp
Hey I just got a fosgate 301 x amp, and was wondering if I got a higher voltage fuse would it sound better and stuff. I was told it would by a car audio tech when I was getting gold plated rca plugs and ground wire. I would think this would hurt your amp but I honestly don't know. What are your thoughts on this?
Old 12-09-2003, 07:46 PM
i_a_n112784 i_a_n112784 is offline
Send a message via AIM to i_a_n112784
First, I think you mean a higher amp fuse, all cars (except military and REALLY old) are 12v. And those big 100amp fuses some people have are a waste of money unless you have a HUGE amount of equipment you are powering. I have a 30amp fuse, nothing special, just one you'd find under your dash, and it powers 1600watts.
Old 12-21-2003, 12:27 PM
CR50HC CR50HC is offline
Fuse Replacement?
Sorry, but you will not gsin sny performance by replacing your fuse. If you want your system to produce more power or, higher volumes at clear levels, you will need a bigger amplifier. Troy
Old 12-21-2003, 09:03 PM
unusualcivic's Avatar
unusualcivic unusualcivic is offline
Send a message via AIM to unusualcivic
Re: Fuse for amp
1600 watts on a 30 amp fuse?
you would need a 140 amp fuse to support that kind of wattage, if it was real power, not that theoretical peak before meltdown most manufacturers use. 30 amps equates to about 300 watts of power.
84 Civic 1500S
engine- T3 D16a1 with built bottom end in the works
interior- MOMO seats, Sunpro guages, RCI 4-point harness,
sound system- clarion DXZ825, RF Fanatic P's RF 351S, 1 Eclipse SW6123DVC (currently saving for another)
exterior- satin black in progress
Stock Radio for installing Subs/Amp? robkule422 Car Audio 8 02-01-2011 07:29 PM
Blown fuse/fried amp? deXtrous Car Audio 7 06-15-2007 02:27 AM
Wiring for cd deck install needed for amp bypass! hahnmon22 Galant 2 04-01-2005 11:57 PM
1996 Accord Ex Alternator Power for Amp????? alsolgiaoihf Car Audio 1 02-19-2002 01:22 PM
firewall hole for amp wiring? bump909 Audio/Security 10 08-22-2001 06:27 PM
