Old 12-08-2003, 02:03 PM
Kaleco Kaleco is offline
Send a message via AIM to Kaleco
Transmission Lock!?!?!
Yea my car broke down on me once again for like the 3rd time ever own'n this car and i've only had it bout 6 months....need help with what the problem would be im driving and all of a sudden i hear a loud as bang...kind like i hit sumthing or ran sumthing over...than my tires lock'd up and i was stuck...im on a hill my car is in neutral and it won't even roll forward no ebrake no footbrake on at all juss sittin in neutral on a hill not moving...i put my car into Reverse and it would move back a very lil bit and than it would buckle and juss stop...than i would put my car into drive and it would buckle when it got to the point i was first at...i could'nt push my car anywhere either when in neutral...my car was able to turn on and off...my engine rev'd and it went into gears...that's why im puzzle'd by this issue what could it be?
Old 12-08-2003, 10:45 PM
DragonRacinImports DragonRacinImports is offline
Send a message via AIM to DragonRacinImports Send a message via Yahoo to DragonRacinImports
good clutch? and a used transmission i can get for 200 with 50K miles or less on it.
Old 12-09-2003, 12:49 AM
EclipseRST's Avatar
EclipseRST EclipseRST is offline
Banned
Send a message via AIM to EclipseRST Send a message via MSN to EclipseRST Send a message via Yahoo to EclipseRST
did you look at the tranny at all? check your tranny fluid also, that could be low causing it to lock up, but i'm not sure why it would make a bang like that... make sure that your tranny doesnt have any holes in it, one of my friends shift pin on his tranny came loose, sent it and some gears through a hole the size of a grapefruit in the side of the tranny... luckly it still had warrent, good luck with that, hope its just the fluid, let us know what you find out!
Old 12-09-2003, 01:37 AM
kjewer1 kjewer1 is offline
AF - Advisor
It would really be helpful to include what the hell the car is I'm guessing its an AWD and a 5spd, since thats the most common configuration. I'll bet the tcase failed. Pull the drain plug and see if any fluid comes out. Should be half a quart and free of metal chunks If the fluid seems normal, or its not an AWD, most likely something broke inside the tranny and is jambing up the gears. But this typically wont lock it up in both directions (forward and reverse), while a tcase will.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 12-31-2003, 08:11 AM
W-44Olds W-44Olds is offline
Yep. If it is awd as already said it was probably the transfer case.This is common on the awd cars.So much so there was a recall.If it locked and the recall work was not done it will be to late.Just be glad you were not going really fast, a lot of people have been hurt and even killed.Chrysler.com has a recall section click on it and run you VIN number it will tell about any recalls on your car. It will also tell you if the work is completed or not.Recall work is free so it is always good to check! Sorry about your luck.
My tranny is locked/jammed, I can't shift it out of gear. Help please! danm1985 Engineering/ Technical 2 08-23-2009 11:36 PM
Poor transmission lockup robbie_NH Roadmaster 3 07-07-2009 07:14 PM
Transmission locked - can't start-1997 deerader Sebring | Sebring Coupe | Convertible 1 08-12-2004 09:32 PM
95 Windstar Transmission - Lock-up In and Out Engine_Mapper Windstar 9 03-24-2004 02:39 PM
Transmission locks in Park in cold weather rpshryock Off-Topic 6 02-07-2004 11:58 AM
