Go Back   Automotive Forums Car Chat > Mercury > Villager
Old 12-08-2003, 12:00 PM
hlh hlh is offline
95 Villager remote unlock won't work
Hi all, I have a 120k miles Villare GS that just started having a problem with the lock/unlock remote. About half the time it won't unlock the vehicle. I can still gain access with a key but the van won't start unless the remote unlock button is pressed because this allows the starter to engage. I guess this is a security features. I've replace the battery and the remote but no change. Everytime it does this, and won't start, I remove the negative terminal off the battery, reconnect, and then it'll start. But it's kind of a pain to do this for almost every start.
It's almost like the remote radio receiver doesn't always receive the signal. I'm not sure where to start. It's a shame a small electronic device may bring an otherwise great vehicle to it's knees. Any suggestions?
Old 12-08-2003, 02:05 PM
hlh hlh is offline
Maybe what I should be asking here is how do I turn off the Villager security system?
Old 12-29-2003, 08:57 PM
eltigre eltigre is offline
Re: 95 Villager remote unlock won't work
Looks like what you may have is a bad timer module or inhibit relay or anti-theft relay............
But to me it sounds like its the inhibit relay( its located in relay box by the radiator ); remove it and look at its prongs; hold it in a way to make the prongs look like a "U" shape; the prongs are numbered as follows:
upper right #1
upper left #2
under #1 is #3
under #2 is #6
bottom middle is #4 and on top of #4 is #7
......use a jumper wire from positive terminal on battery to the #1 terminal and then use another jumper from neg terminal to #2; now with an ohmeter check the resistance between prongs #4 and #7; If it is more than 5 Ohms then your relay is bad....let me know what you get and I can help you further
Old 12-30-2003, 06:25 AM
hlh hlh is offline
Thanks for the reply. I ended up having the dealer disconnect the security system. I'll look into your fix and possibly reconnect the system.
94 Mercury Villager Hard start - engine shakes - stalls out runnergirl262 Villager 6 02-12-2010 10:28 PM
prostart remote starter won't work Whiterhino Cherokee 6 04-21-2007 08:47 PM
99 Villager Estate Remote Start Not Working skautpiwny Villager 0 03-02-2007 11:02 AM
1999 Silverado Keyless remote won't work jbrooks21 Silverado 6 10-25-2006 05:40 PM
