Old 09-21-2004, 07:57 AM
jbrooks21 jbrooks21 is offline
1999 Silverado Keyless remote won't work
I have tried all three proceedures for programming my existing remotes. For some reason they just stopped working. When i tried to go thru the ON,OFF,ON,OFF the dor lock did not cycle. When i went thru the Pin 4 and Pin 8 programing it did nothing. What am i doing wrong?
Old 09-21-2004, 08:10 AM
sitdusa sitdusa is offline
keyless remote
What I did to reprogram my remote (98 Z-71) was to press and hold the unlock and lock buttons for 5-7 secs. Make sure you have your windows rolled down and all he doors closed. Within 5-7 secs the door locks should cycle through and your done.
Old 09-21-2004, 10:42 AM
Re: keyless remote
I tried that but and it did not work. My problem is that when i tried to program it the door locks did not cycle.
Old 09-23-2004, 06:40 PM
Silver X Silver X is offline
Re: 1999 Silverado Keyless remote won't work
You might try to diconect the battery for A few min and reconect and try it again....
Start with ignition off.
2. Press and hold unlock button on drivers door, the locks will cycle once.
3. Turn ignition on-off-on-off.
4. Release unlock button, the locks will cycle once.
5. Hold down lock and unlock keys on keyfob transmitter until locks cycle (about 15 seconds).
6. Repeat step 5. for remaining keyfobs (up to 4 total)
7. Turn ignition on to exit the programming mode. Programming is now complete
On step 5 you have to hold down the unlock and lock buttons on the remote at the same time till you see the doors lock then it will be complete...........
Old 02-15-2006, 06:05 PM
gunsjacklw gunsjacklw is offline
Here you go http://autorepair.about.com/library/faqs/bl940g.htm
Old 02-20-2006, 10:11 PM
Onblsht's Avatar
Onblsht Onblsht is offline
Authorized Vendor
Are you sure you have the correct remote:
It should be FCC: KOBUT1BT / GM #: 15732803
Replacement keyless entry remotes available here - up to 90% off -
All makes/models from Acura-Volvo, 1988-present -
http://www.OriginalKeyless.com
Old 10-25-2006, 05:40 PM
moaffer moaffer is offline
I have the same problem, my locks won't cycle; indicating in programming mode. Any answers?
