Go Back   Automotive Forums Car Chat > Chevrolet > Monte Carlo
Old 12-05-2003, 08:21 AM
murphy517 murphy517 is offline
left brake light out only
everything is functioning except the left brake light. checked bulbs. signals ok. took to garage and they said i needed a new signal switch. when i left, no signals working. took back and (although not admitted by mechanic) button for hazard was also broken off. said dust etc. could get in hazard so he messed around with it and all was working, so i told him just to glue it back on. the signals once again are working so i was back to square one. but mechanic said signal switch will eventually go and have to be replaced.
1. is what he told me about the signal switch valid?
2. i had assumed when i brought it in, there was just a broken wire or bad socket since it was only the brake light on the left side - should the mechanic have looked at that first? i was told after he checked the bulb he went to the signal switch.
thanks so much for all your help!
Old 12-23-2004, 09:34 PM
marqis marqis is offline
Re: left brake light out only
Mine light brake light wasn't working either.Had turn signal switch replaced. Now no problem hope this helps.
Old 12-24-2004, 11:30 AM
dwalmop dwalmop is offline
I wouldn't doubt the signal switch at all. They're junk, and they go bad constantly. Replace it - even if you're not sure, because eventually, it will go bad anyway.
1999 Passat - Changing Brake light bumpsetspikeki11 '97+ 0 03-09-2010 07:38 PM
emergency brake light comes on freakyfire05 ZX2 8 02-11-2010 10:19 AM
Brake Light Switch uspres2020 Escort 5 09-28-2009 12:11 AM
Brake lights problem corollastudent Corolla/Matrix/Voltz 1 07-20-2009 12:39 PM
Locked front brakes, brake light out, headlights gone kruqnut Problem Diagnosis 19 02-26-2009 08:49 AM
