Old 12-03-2003, 03:36 PM
MachoCamacho MachoCamacho is offline
93-02 Z28's
Alright, the Manuals were 6 speed but how many were the automatics? 4? or 6?
Old 12-03-2003, 03:43 PM
BlkCamaroSS's Avatar
BlkCamaroSS BlkCamaroSS is offline
Send a message via AIM to BlkCamaroSS
Re: 93-02 Z28's
A4 and M6
2001 Camaro SS #2239 of 6332
1/4 mile time: 13.575 @ 105.55 mph, 60' time: 2.276
307.1 rwhp, 330.1 rwtq = 353.2 hp, 379.5 lb ft torque
Options: SLP Front Grille w/ SS Center Logo, 17" ZR1 Chrome rims, 6 speed, Hurst Short Throw Shifter, Monsoon 500 Watt Sound System, T-tops, 1LE Performance Suspension
Mods: Holley PS Air Filter, SLP Air Box Lid w/ Mr. Ed's pipe fix, SLP CAI, SLP Bellows, SLP LM, SLP Y-pipe, SLP 160 Thermo, SLP Temp Module, SLP STB, KBDD SFC
Old 12-03-2003, 03:44 PM
StingRay_68 StingRay_68 is offline
It's a 4 speed... but sometimes when you drive it, it feels like it's got like 6 gears that it slips in and out of. Sometimes slips in between 1st and 2nd... 2nd and 3rd... 3rd and overdrive... It's annoying.
I'm getting an SS next year with a 6 speed. Autos are just boring.
Old 12-04-2003, 04:15 AM
SONIC1050fps SONIC1050fps is offline
Re: 93-02 Z28's
Auto's are fast. put a stall a transgo and nittos' and expect a drop of .75 second. even though 7 out of 10 races are won by auto'' boring.. wining isn't boring
consistancy.. yucan't outshiftthe4l60 e.. right now the best aut Amrica make. yeah try chrping 3rdstock in any other
lol
you'e onof those ego guys who thinks 3 pedals makes a sports ar.
and that .75 drop.. is withugh ading any hp no bolt-ons nothing.. see you at the track
Old 12-04-2003, 07:21 AM
Re: 93-02 Z28's
I chirp third all the time in my M6, and three pedals do make the sports car, it's more fun that way
Old 12-04-2003, 08:27 PM
CamaroSSBoy346's Avatar
CamaroSSBoy346 CamaroSSBoy346 is offline
Send a message via AIM to CamaroSSBoy346
Re: 93-02 Z28's
4l60e fo life y0! Especially when you use it manually.. 1-2-D-OD. I think i need a Hypertech.
2002 F150 SuperCab FX4 6" Fabtech, 3" BL, Detroit locker, Edge tuned, Yukon 4.56s, 37" Nittos, Harley lights, Depo fogs, 8K HIDs, Powerstop brakes
1992 Lincoln Mark VII LSC 302 H.O, A9L ECU swap, 65mm TB, 73mm Granetelli MAF, FRPP 30lb injectors, Walbro 255, MSD ignition, Powerdyne BD11 supercharger, Efans, T-5 swap w/ FRPP flywheel, Ram HDX clutch and adjustable Steeda clutch quadrant, 4.10 gears, Nitto NT555R radials
2000 OBS Tahoe Z71 6k HIDs, 33" Goodyears. 280k mile daily beater
Old 12-04-2003, 08:34 PM
1979C10 1979C10 is offline
Send a message via AIM to 1979C10
Re: 93-02 Z28's
Yeah, manuals ARE a lot more fun to drive, but if your drag racing, an auto is a lot more consistent
Old 12-04-2003, 08:36 PM
Z-Almighty's Avatar
Z-Almighty Z-Almighty is offline
Send a message via AIM to Z-Almighty
Aight this might be slighlty off topic but was the 4l60-e in use in 93 or was it put in in 94?
Old 12-04-2003, 08:39 PM
Re: 93-02 Z28's
Don't know, I think they were still running 700R4's in 96 with the impala, so I would imagine the same for the camaro. Correct me if I'm wrong.
Old 12-05-2003, 10:00 PM
hot_red_z28 hot_red_z28 is offline
Send a message via ICQ to hot_red_z28 Send a message via AIM to hot_red_z28
Re: 93-02 Z28's
1993 saw the introduction of the 4L60, notice the lack of the "e". It was basically a 700R4. The 4L60E was put into the 94+ LT1's, and is basically a 700R4 that is electronically controlled...
BTW, for those of you that manually shift your 4L60E's, I highly recommend that you don't. You can burn them up fast. They are not meant to be shifted manually. Just throw it into D when you are going to race, and leave it there. If you don't think it shifts at the right spot, get your PCM reprogrammed, or buy a hypertech and adjust the shift points yourself. You should just be able to pin that bitch and have it run the best times possible, and not shift it yourself...
My Project Write-Up
Old 12-07-2003, 12:51 AM
GOOOD REPLY HOT RED Z28! Take that to note, autos arent meant to be manual...theyre autos people you'll kill your car
Old 12-07-2003, 04:44 AM
DVS LT1 DVS LT1 is offline
Re: Re: 93-02 Z28's
I originally wasn't able to use "1" - because of some bullshit noise pollution law or other mine was locked out. I had to pop up the shifter console and cut away this little piece of plastic that was blocking it.
But I can tell you my tranny has gotten dumber over the last two summers from screwing around with the gears. Its brutal cause my gears are really tall and a lot of times it won't downshift into first even at like 25 Mph - so I'm stuck in second gear from 25/30 Mph to 85 Mph. BRUTAL!!!!!! And it never used to be like that - I could be going 40 Mph and she'd drop into first at like 5000 PRM and run all the way up to 6000. All by herself.
I'm eyeing a 600+ HP dyno'd 700R4 as a replacement - hopefully in mid summer.
Old 12-07-2003, 12:55 PM
Re: Re: Re: 93-02 Z28's
There ya go, DVS is a prime example of what can happen from manually shifting a 4L60E. It's just not a good idea, and might result in a situation like his...
My Project Write-Up
Old 12-07-2003, 04:09 PM
BigJustinZ28 BigJustinZ28 is offline
Re: 93-02 Z28's
hehe , manually shifting a 700r4 is a fun experience however . Put a ratchet shifter on the 84and its much better when you do it yourself. From what I've seen the older 700r4's shift way to early on the HO motors.
1984 Z28 = 305 HO w/ 700R4
flowmaster , k&n filter , B&M Megashifter
91-92 z28 dress w/ 94 z28 wheels
1997 Camaro Z28 = LT1 w/ LT4 Conversion w/ Hot Cam
52mm T/B , SLP CAI , SLP Shorties .Eibach Springs, KYB GA Shocks.
SS Hood , Suncoast Creations Spoiler , F1 Camaro Wheels.
30th Ann. Style White with Orange Stripes.
Old 12-07-2003, 05:47 PM
Re: Re: 93-02 Z28's
Justin when did you pick up the '97 Z?? Nice score - lets see some pics bud...
Randegos
How To: 93-02 T-top conversion 666_speed Appearance: How To... - FAQs 35 07-05-2006 08:36 PM
93-02 rear end center peice//decal??? MidwayAvenue Camaro Discussions 0 03-09-2006 10:43 PM
Camaro 93-02 Carbon Fiber Hatch ViperJ Camaro Discussions 14 09-19-2005 02:13 AM
what rearend gears came stock for camaros from 93-02? roddiesel23 Camaro Discussions 2 06-20-2004 09:24 PM
Torque/HP changes 93-02 Z28 MachoCamacho Camaro Discussions 7 11-18-2003 10:29 PM
