Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 12-03-2003, 02:00 PM
s2000FREAK s2000FREAK is offline
Send a message via AIM to s2000FREAK
Lightbulb just got my s2000 and need advise and help!!
ok here's the deal..i just got my new 2003 s2000 and i want the best mods for it so this is wat i need.
i wanna install a twin turbo system, but w/ small turbos....i wanna know if i can run nitrous w/ that and if so how would i go about it. also if u have advise to what i should do to it to get peak performance plz feel free to share
Old 12-03-2003, 02:17 PM
Ace$nyper's Avatar
Ace$nyper Ace$nyper is offline
Banned
Send a message via AIM to Ace$nyper Send a message via MSN to Ace$nyper Send a message via Yahoo to Ace$nyper
TT on i-4 bad yea you can use n2o. best place to start is if you really going to go turbo do that and if you want a supercharger or want to go allmotor start with intake header exhaust. If your going turbo think about what you want the car like so you can make up your mind for what you want something like a t-25 would be a good smaller turbo.
Old 12-03-2003, 04:28 PM
Re: just got my s2000 and need advise and help!!
i need the car for cross country type races...u know tight turns and quick start ups...ya know. so basically i need somethin that can start up fast, keep a nasty speed and return that speed afta makin a huge turn. so wat kinda mods u think i should do now that u have that info
Old 12-03-2003, 04:34 PM
Ace$nyper's Avatar
Banned
well a t-28 or a t3 maybe t3/4 would all work. Umm t4 with shot of n20 for helping spoll teh turbine. get good set rims and tires. Also Supercharer would work lots of people here don't like them but i've been in a S2k with one and other work it FLEW!
Old 12-03-2003, 05:29 PM
Zonathin Zonathin is offline
you don't really hear too much of people putting a turbo in an S2000, but if you want to then by all means go for it. however, most people go with the supercharger and that goes without complaint. (from most people). therefore, supercharging your S2000 is a safe bet.
Old 12-03-2003, 05:57 PM
tran_nsx's Avatar
tran_nsx tran_nsx is offline
heres are some dynos for a comptech s/c s2k, not very impressive if u ask me , but atleast u don't have to worry about lag
http://www.importreview.com/d_supercharged.html
Old 12-03-2003, 09:38 PM
so basically a supercharger would work best for the type of car im askin for....hmm sounds pretty good, wat kind do u recommend? i mean keep in mind wat kind of car im tryin to make here and im kinda new at makin performance cars so i could use all the help i can get
Old 12-03-2003, 10:02 PM
Thepeug's Avatar
Thepeug Thepeug is offline
Quem queritis?
Send a message via AIM to Thepeug
Jackson Racing, Comptech and Vortech all make superchargers for the s2000. A JRSC is the cheapest, but as with most performance parts, you get what you pay for. Check out each company's website to compare. Also, by 'cross country' did you mean autocross? If so, definitely go with a S/C. The lag on a turbo would be a disadvantage when you have to constantly brake and make tight turns.
Peace, love, and premium octane.
Old 12-03-2003, 11:04 PM
both comptech and vortec have a little bit of lag i believe. JRSC's don't really have any lag at all. if you need the power right away, i think JRSC's are the way to go. comptech's website said that it makes the power in the high rpms. either way, choose what's right for you application
Old 12-03-2003, 11:55 PM
GScivic7's Avatar
GScivic7 GScivic7 is offline
Send a message via AIM to GScivic7 Send a message via MSN to GScivic7
does JRSC make a centrifugal SC for the S2K like the Comptech and Vortec does? I've heard some bad things about the roots type blowers on 4 cylinders.
Empty Pockets Racing Member #1
Old 12-04-2003, 12:48 AM
Thepeug's Avatar
Quem queritis?
A supercharger doesn't have lag. Power in high rpm's just means that most of the noticeable power gains don't come until you're in the upper part of the power band. An S/C make power exponentially. Even at 2000 rpms it's making power; it may not be a lot of power, but it's there. A turbo, on the the other hand, literally doesn't make any power until it has spooled.
Old 12-04-2003, 12:42 PM
"thepeug" thnx bro that was extremely helpful, and yea i meant autocross.....so basically i should get a supercharger instead. sounds like a real safe bet. but now another question...can NOS be safely used w/ superchargers while keepin the original engine on the s2000 alone? because i heard rumors that its too much to take and id blow the pistons and stuff in my car. i deff dont want that so i need to know ahead of time b4 i go out and order parts. and would i need an intercooler for the supercharger....no rite?
Old 12-04-2003, 02:06 PM
turbo2nr's Avatar
turbo2nr turbo2nr is offline
Send a message via AIM to turbo2nr
Re: Re: just got my s2000 and need advise and help!!
ok you build you internals, new pistons, rods, you know the works bulletproof bottem end, lower compression to 9:1 and get some better cams, put a mid-sized single turbo, like a t04-e and turn to boost to 16psi and you should make an easy 350+hp
and since you internals are built you can boost more.. and do the fuel managment regardless of turbo or s/c you need more fuel for more air. i say get a new fuel pump and regulator that is higher flowing , and do the exhaust system as well and get a fuel air managment device to tune all the mods ..
good luck
1
Shift_BOOST
97 s14
Old 12-04-2003, 02:40 PM
hey turbo2nr is it really nessecary to do all those mods to the car? im addin a vortech supercharger and NOS if i can safely use it during a race w/ a supercharger. obviousely imma do intake exhaust and suspension too.
Old 12-04-2003, 06:39 PM
boosted331 boosted331 is offline
Not having a lag with a centrifugal is BULLSHIT! You have to wait untill redline to make full boost, how is that not lag? just look at the powerband, the curve absolutley sucks on centrifugal blown high RPM cars.
just got a 85 need help lazymayhem Mighty Max 0 12-03-2005 09:56 PM
'96 Blazer I Need Advise and Help Ltl_red Blazer 6 12-13-2004 05:37 PM
i just got a 1990 rx7 gxl and i need help please!!! Speed1Rx7 RX-7 2 04-01-2004 09:12 PM
just got a 240sx need some first mod help...Please NiSmO_zt 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 20 08-22-2003 06:55 PM
Just got an 02 and need some install help ricergurl '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 3 07-05-2002 12:06 AM
