Old 12-02-2003, 06:38 PM
my91crxsi my91crxsi is offline
need info on swapping b18a1 to 91 crx si
im swapping b18a1 into 91 crx si and i need to know what wiring mods need to be done, is the crx obd-0 or 1??
any help would be appreciated
Old 12-02-2003, 06:46 PM
91civicDXdude's Avatar
you need a mount kit and shift linkages.
extend the TPS and EACV.
OBD0.
Use the PR4.
Old 12-02-2003, 07:10 PM
im a little new to all of the wiring aspects of the motors, if you could explain the pr4 to me?
Old 12-02-2003, 11:27 PM
the PR4 is the 90-91 Integra OBD0 ECU. Use it with the engine as it will work properly with the PM6 (Civic/CRX Si ECU) but it will run very rich and wont be tuned correctly for use with b18a1.
Old 12-03-2003, 04:22 PM
Re: need info on swapping b18a1 to 91 crx si
ok, i have the ecu, and wiring harness for the engine, but its from a 93 ls, is that usable
also which harness would i use??
thanks again for the help
Old 12-03-2003, 11:32 PM
do you recommend finding the ecu from a 90-91 b18a1 and using it with a modified crx harness so all of the obd's match up, if that would work??
and does anyone know where i can get some axles that will fit this swap, i checked on raxles.com but im wondering if there are any stock ones that would work
Old 12-04-2003, 12:50 AM
just buy axles from autozone or something, they are lifetime guarantee and about $60 per side. (91 acura integra LS)
I would suggest that you take the b18a1 wiring harness off the engine and use your stock crx si one. it will connect right up to everything.
Find and use a 90-91 OBD0 PR4 ECU. If you cannot find one, message me, i have a couple laying around. we can work out a trade or something.
Old 12-04-2003, 04:41 PM
cool i'll keep that in mind,
this may sound like a dumb question but i dont have the crx yet im buying it from a friend, this swap was originally intended for a 95 civic,
but the crx tranny is cable right, and if so are there any other cable trannies with better gear ratios than the ls,that will fit the engine?
Old 12-04-2003, 05:02 PM
kris's Avatar
kris kris is offline
Off playing with fire.
The B16 and B17 transmission.
Old 12-04-2003, 06:46 PM
what year/s was the b16 tranny cable?
93 D16Z6 swap into 91 CRX SI, Need help riptech7 How-To's and Walk-Through's 2 01-08-2010 08:48 PM
i need help with my crx... i need info zkhan Exterior | bodykits | Lighting 2 11-27-2006 01:11 AM
*help!! info on b18a1 into 91 crx dx knack knack How-To's and Walk-Through's 2 08-04-2005 10:45 PM
87 crx in need of swap info B-boy D JDM Motor & Parts info/chat 2 10-12-2004 05:17 PM
I need info on the CRX. NissanDude555 '88 - '91 Civic | CRX | Wagon | Shuttlee 8 04-09-2004 05:08 PM
