Old 04-08-2004, 10:40 PM
NissanDude555 NissanDude555 is offline
I need info on the CRX.
Hey guys, can anybody give me some info on the crx's.
Whats the most powerfull version of them??
How much added horsepower can a stock crx take without having any problems??
Lets say I have about 3000 to use for modifying my crx..............
WHat can I do to make my crx be a horsepower monster and go fast as hell without actually turbocharging it or swapping engines??
How much horsepower would be added if I was to install good quality header, cold air intake, and exhaust??? What else can I do to boost performance???
What are the horsepower adding stages for crx??
How much nitrous can a crx take???
Whats the most horsepower I can get without turbocharging or swapping engines??
WHats the most horsepower I can get from turbocharging it???
... dont hesitate to add more info which I did not ask. thanks dudes.
Old 04-08-2004, 11:26 PM
Chen's Avatar
Chen Chen is offline
Re: I need info on the CRX.
It sounds like you don't want to swap engines, but it would almost be better than to build up the stock engine. There are two common Integra motors that will bolt right in with the right mounts (b18c1 GSR and b18c5 Type R). And if you want to be really extreme you can put the h22 prelude engine in, but it'll take some work and possibly some modification as well. The Integra engines range from about 180hp-210hp.
Old 04-08-2004, 11:33 PM
PunkAlex's Avatar
PunkAlex PunkAlex is offline
Send a message via AIM to PunkAlex
On the US shores, it was the CRX Si, with about 100 hp out of a 1.6L SOHC MPFI engine.
Thats a little too broad to answer. The stock Si motor can take like 200-225 on stock internals.
Uhhh putting 3k into the stock engine is a waste w/o forceinduction. Its not (that) good for all motor applications, so youd be throwing the cash away
in total, probably 7-15 whp, 15 being extremely hopeful IMO You can get your ecu remapped. You could do a vtec head swap and get 20 or so hp. Lotsa little things too.
There are none to my knowledge.
probably 75 wet shot w/ accelorated wear/tear
im assuming turbo means all force induction (nitrous included) probably a little over 200 whp. More probably. I dunno im jsut now studying d series.
Thats uhh...err...kinda open. On stock internals, 200-240. FUlly build, probably 350-400.
I'm Alex. A cookie to whoever guesses what car I'll get!
I tend to hate people....expecially liberals...
This is my temporary racecar-the two liter beast itself, the 87 camry:
Old 04-09-2004, 10:45 AM
d16a6crx's Avatar
d16a6crx d16a6crx is offline
Swap in a b18a1 out of a 1990-93 Integra, lots of torque and cheap too.
If you don't want to swap engines, you could use a SOHC VTEC head from either d16z6 or d16y8... D series engines can get about 150-160hp N/A and still be very streetable...
1991 CRX Si
Looking for 88-91 Sedan or Hatch
Old 04-09-2004, 12:56 PM
whats a d16y8 and d16z6? and b18a1?
Old 04-09-2004, 03:28 PM
PunkAlex's Avatar
A d16y8 is a SOHC VTEC OBDII motor out of 96-00 civic vtec (exept 99-00 Si). Its making ~135hp.
A d16z6 is a SOHC VTEC OBDI motor out of 92-95 civic vtec. Its making ~125-130hp.
A b18a1 is a DOHC nonvtec OBD0 (?) motor out of ??-?? acura integras. ITs making ~130hp w/ WAYYYY more torque than the SOHC motors.
Old 04-09-2004, 03:40 PM
d16a6crx's Avatar
the b18a us OBDO and in found in 1990-93 integras
1991 CRX Si
Old 04-09-2004, 05:05 PM
optimuscivic's Avatar
optimuscivic optimuscivic is offline
b18a1 came out of 90-93 integras. the 90-91 has 130 hp & 121 tq. 92-93 tegs were obd1 and 140 hp 127 tq. they have more aggressive camshafts.
As American As A Burrito!
USDM 4 life!
Old 04-09-2004, 05:08 PM
with 3000 dollars i would do a b series swap or d series turbo. not worth the money to put i/h/e on a stock d series motor.
USDM 4 life!
