Go Back   Automotive Forums Car Chat > Engineering/ Technical > Tires and Wheels
Old 12-02-2003, 03:57 PM
MR2_Lancer MR2_Lancer is offline
Send a message via AIM to MR2_Lancer
1990 Chevy S10 - will camaro rims fit?
alright, ive been lookin and their the same bolt circle. 5x4.75...i just need to know if they would be too wide or anything...please let me know.
GreG
Old 12-02-2003, 04:32 PM
Grant@Tirerack's Avatar
Grant@Tirerack Grant@Tirerack is offline
The only thing they share would be the bolt pattern. The main worry I can see would be the load ratings. Camaro wheels are not going to be able to handle the stress of a light truck. They would not have enough load capacity.
Grant
Your personal contact at The Tire Rack
1-877-522-8473 ext# 313
fax# 574-236-7707
email: [email protected]
Old 12-03-2003, 06:26 AM
alright grant...break it down for me...lol. i need a lil explanation cause im not too sure what you just said. what other problems would i encounter though? thanks for answering though.
GreG
Old 12-03-2003, 12:00 PM
Light truck wheels are going to have a higher load rating than a car wheel. Due to the differences in load distribution on a truck (they are top heavy) and suspension, truck wheels have a higher load rating than a Camaro. The offset and back spacing will not be the same on many of these as well. I would stick with something designed for that type of vehicle.
Grant
fax# 574-236-7707
Old 12-03-2003, 03:18 PM
ok, say i put the set on there...what problems would i face driving? i dont do work with the truck and shes lowered 3/4. how would it affect everyday driving to school and work and around town?
GreG
Old 12-04-2003, 11:27 AM
If the wheels are not load rated for the truck you can expect the wheels to be more prone to damage from stress or impact. If they do not have the correct offsets for the truck's hub, you can expect premature wheel bearing wear. Most of the Camaro offsets are way off for what you would need on an S10.
Grant
fax# 574-236-7707
91 Chevy s10 p/u with a high idle. need help! IndianaRedneck S-10 2 12-19-2010 08:14 AM
Will 15x8 rims fit on 1985 S10 4x4?? ralinjersey S-10 1 04-04-2004 08:42 PM
Chevy Extreme Will Z06 Rims Fit CorsaliniGTR S-10 3 01-30-2004 10:05 AM
Will 8x17" rims fit on an ITR? Veetec Integra 12 12-13-2001 10:38 AM
