Old 12-01-2003, 04:12 PM
walkerdill walkerdill is offline
Question Please help~Cant fingure out whats wrong
I have a 91 metro and yesterday I started it up and it stalled. Now it wont re-start. It turns over like it wants to start but wont. I thought it might be the starter but took it out and had it tested and its fine. The timing belt wont turn either. Has anyone had this problem? Perhaps you make know what it is?
Thanks
Charity
Old 01-06-2004, 01:03 PM
codboy codboy is offline
Re: Please help~Cant fingure out whats wrong
it probably flooded due to bad distributer cap/rotor and maybe even plugs and wires I had the same problem
Old 01-16-2004, 04:39 PM
sezI sezI is offline
flooded
Try this,
Pop the hood and disconnect the wire for the fuel injector.
(You might have to remove the air cleaner to gain access, If you've done this a couple of time you probably won't need to.)
Then turn the motor over, with the injector unplugged.
Once it starts it will run for a few seconds then die.
When it does go back under the hood and plug the injector back in.
It should start and run, let it idle for a minute or two before you take off.
Good luck.
Old 01-17-2004, 12:19 AM
geozukigti geozukigti is offline
is the engine turning when you start it? or is it locked? you said something about the timing belt not moving
need help to figure out whats wrong with my car caminsc5 '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 2 12-06-2004 03:24 PM
i need to find out whats wrong with my car!! bmoreboy52 Off-Topic 1 11-08-2004 04:26 PM
My stupid civic trying to work out whats wrong! Rufes1 '88 - '91 Civic | CRX | Wagon | Shuttlee 3 04-08-2004 12:28 AM
PLEASE HELP!!!!! Don't know whats wrong with this thing tonys89honda Accord/TSX/Accord Hybrid 3 01-23-2004 07:15 PM
Found out whats wrong with the civic.. discented '88 - '91 Civic | CRX | Wagon | Shuttlee 9 04-23-2003 04:19 PM
