Old 12-01-2003, 05:42 AM
pdon pdon is offline
91 Civic Speaker Wiring In doors need HELP!!!
How would i got about putting new wire throught to the doors i cant get the wiring harness out of the door and i dunno where to feed the wiring through. This is on a 91civic Sedan
Old 12-20-2003, 07:46 PM
CR50HC CR50HC is offline
Thumbs up Use Factory wiring
From my car audio experience, I've found it best to use the factory wiring when it comes to the doors. Why? It's a big hassle to remove the rubber grommett and rewire everything. You reeally won't see a real difference in sound quality of that (very short) run of factory wire. You can run your amplifier to the front speaker outputs on the dash wire harness (the one you used to connect an aftermarket radio with). By the way, if you remove the factory 5 1/4" speaker baffles, you can run a 6 1/2 woofer in those doors. be careful of the mounting depth. If I'm right, you can only get by with a 6 1/2 that's 2 inches deep. Troy
AMP/Speaker wiring in cooler boom box Chupacabra111 Car Audio 6 12-20-2010 05:29 PM
Speaker wire replacement mikeburrit01 1st Gen 95-99 0 09-27-2010 09:31 PM
Need Help With Wiring of Side Mirror!!!! civdub21 How-To's and Walk-Through's 0 03-27-2009 07:05 AM
Need Help With Wiring of Side Mirror!!!! civdub21 '96-'00 Civic 0 03-26-2009 10:20 PM
2dr 94 Civic speaker wire help!!!! jiggydragon Car Audio 0 10-27-2003 12:19 AM
