Old 11-28-2003, 01:40 AM
Kasso's Avatar
Kasso Kasso is offline
Send a message via AIM to Kasso Send a message via MSN to Kasso Send a message via Yahoo to Kasso
Brake detail help needed...
I searched and searched and couldnt find what im looking for...
how can i accurately drill holes on a plain disk brake like from the Revell ITR? is there a simpler method than measuring each and every rotor?
1995 Acura Integra Special Edition (something real special about a 5000 rpm changeover... )
Old 11-28-2003, 01:45 AM
SchuberT's Avatar
SchuberT SchuberT is offline
Re: Brake detail help needed...
i just drilled mine at random... but with a pattern... lol
Read the FAQ please.
https://www.facebook.com/KBModelwerks/
Call me Matthew.
Old 11-28-2003, 02:48 AM
skypie's Avatar
skypie skypie is offline
Send a message via AIM to skypie
Dunno...
Try making patterns on a masking tape, tape it on the disc (better do this first then mark patterns) and then drill thru the pattern...
Old 11-28-2003, 01:15 PM
Ferrari TR's Avatar
Ferrari TR Ferrari TR is offline
Not A Hoarder!
I made a template years ago...
Used a piece of scrap plastic, shaped like a piece of pie with a round cut out shaped like the hub. Drill holes in it where you want the holes in the brake disk, drill holes in the disk, turn the template, repeat...
I hope that made sense!
SCCA 7, The lost Z
Old 11-28-2003, 01:28 PM
Kasso's Avatar
do u have a picture?
Old 11-28-2003, 03:32 PM
slk320 slk320 is offline
AF Premium User
Send a message via AIM to slk320
You have a number of choices instead of drilling:
1. you can replace your strock ITR brakes with a number of aftermarket brakes, BREMBO, AP racing ,etc. you ge these off other models, for example, my GT-R Skyline R34 came with two sets of brembo cross drilled brakes. I also have a number of WRC kit parts, including great looking brakes. Check out my R34 thread for more detail on the brakes.
Here are some examples:
these came from a stock NHRA kit:
these came from the Porsche GT3 kit:
These were also WRC brakes:
2. you can replace the stock kit brakes with after market photoetched units that are 100% more realistic and are easy to assemble. I had great luck with the SAS brake kit that comes with its own resin calipers!! for extra detail...
These are Scale auto brakes: without calipers:
with calipers:
and finaly completed:
behind the wheel:
www.scaleautostyle.com
This is metal brakes on ITR from REvell:
3. you can glue photoetch driller rotor face on tope of your plastic part to achieve a up-sized effect. you can find these in many WRC photoetch sets, etc. some people have some left overs.
Like so:
Hope this helps.
Old 11-28-2003, 05:18 PM
ata's Avatar
ata ata is offline
And actually on real performance and racing cars they don't use the cross-drilled discs that much anymore, as grooved discs are better. The drilled real discs get cracks easier than grooved discs, so why not make grooved discs to model cars too...
Old 11-28-2003, 05:25 PM
Kasso's Avatar
the problem with aftermarket parts is taht im short on money. i wanna do this the cheapest way possible.
Old 11-29-2003, 01:49 PM
blueboost's Avatar
blueboost blueboost is offline
try to cut slots in the rotor, like ata said, they are raceworthy, and easier (then dimpled or cross-drilled) to custom fabricate in 1:24th. just make a template or something 1st. I think they look better too
Old 11-29-2003, 04:38 PM
Kasso's Avatar
do u have an example?
Old 12-26-2003, 12:37 PM
Martin S's Avatar
Martin S Martin S is offline
I made slots by measuring and drilled holes on free hand using the tip of a modeling knife. Some pics:
http://plexxi.c-sam.nu/nsx/nsx.htm
(check under "brakes")
please note that the the brakes are not finished. Needs some sanding and paint...
Old 12-26-2003, 02:34 PM
chaos's Avatar
chaos chaos is offline
AF Premium User
Re: Re: Brake detail help needed...
Martin S - nice work on the brakes. Just wondering how you got such a clean cut circle.
Old 12-26-2003, 05:39 PM
Martin S's Avatar
I used one of these:
and scribed a circle on the plastic card and cut it out roughly with a knife and sanded it down to the scribed circle with a 400 grit paper
Detailed help needed with IMG replacement on '99 Rodeo 3.2L digdesdev Rodeo | Passport | MU 0 08-11-2010 10:16 PM
Stratus Brake Problem, Help Needed Disturbed_One Stratus 4 10-27-2006 04:27 PM
Rear Disc Brake Problem-help needed! fuba Taurus | Taurus Wagon 2 10-07-2005 07:38 PM
86 civic si brake conversion help needed supercivic86 '71-'87 Civic | CRX 27 08-30-2005 02:08 AM
Brake light help needed! HondaSi88 Engineering/ Technical 1 09-14-2002 09:52 PM
