Old 11-26-2003, 11:49 AM
mjshort18 mjshort18 is offline
alpine headunit
i want to get this alpine headunit, it is the cda-7995 and it says that i requires an amp to power the headunit. my question is what kind of amp do i need to power this? also i am going to get 2 amps, 1 for my subs and the other for my speakers, so will one of these amps work? thanks
Old 11-26-2003, 03:08 PM
thewoahna's Avatar
thewoahna thewoahna is offline
Send a message via AIM to thewoahna
If I understand what you are asking, yes, one of your 2 amps will work. The head unit just sends a singnal, no power. So you will need to run the RCA's from the back of the unit to an amp, and then from the amp you will run your speakers.
Whenever at a loss of words, "Woah Na!" will suffice....
AOL IM: WoahNa316
Click here for some of my car pics/stats
Old 11-26-2003, 03:22 PM
Re: alpine headunit
oh ok that sounds good, thanks alot woahna. man you have all the answers don't ya. thanks again
Old 11-26-2003, 05:08 PM
GScivic7's Avatar
GScivic7 GScivic7 is offline
Send a message via AIM to GScivic7 Send a message via MSN to GScivic7
Re: alpine headunit
can you give the link from where you found the cd player. I looked on www.onlinecarstereo.com and they don't say anything like that. However, I'm not sure you two are talking about the same thing. Some Alpine headunits require you to run a power wire directly to the battery to power the headunit because the built-in amp needs more power than what the little 12(?) gauge wire coming off the factory harness can handle. I think that might be what they meant by needing an amp to power the headunit, which doesn't really make sense in the first place.
Empty Pockets Racing Member #1
Old 11-26-2003, 10:12 PM
http://www.crutchfield.com/cgi-bin/S...=1&cc=01&avf=Y go to this
Old 11-27-2003, 08:36 AM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
guys ... as a rule for alpine
79XX has no internal amps
78XX has hi power amp(s) built in
so you will need an amp for every pair of speakers - or a 4 channel amp for the front and rear, or seperate mid and tweeter. You will need another (larger) amp for your bass speakers.
Old 11-27-2003, 09:43 AM
Re: alpine headunit
thanks paul, thats what i needed to know.
Old 11-28-2003, 01:16 AM
integrasedan integrasedan is offline
alpine stereos are awesome
Brand new alpines but sound is horrible. How do I fix it? prosportsdude33 Car Audio 9 05-13-2009 11:53 AM
1985 k10 headunit wiring redka88 C/K 0 04-22-2009 08:53 PM
Alpine Changer to Eclipse Headunit? Future Boy Car Audio 1 11-16-2006 09:34 AM
FS: Alpine headunits, RE Subs, JL 8w7, etc GSteg Interior | Audio | Security 2 04-27-2004 09:55 PM
