Go Back   Automotive Forums Car Chat > Alfa Romeo > 156
Old 11-24-2003, 03:34 PM
harv28 harv28 is offline
Angry Standard Running Temperature
Having a few problems with my 156. Car seems to run very hot even at low revs and at a constant speed. Usually runs in excess of 90 degs, is this the norm as the temperature increases quickly without too much provocation. Has anybody else had problems and if so what was the solution.
Many thanks
Harv
Old 11-26-2003, 09:23 AM
franzzz franzzz is offline
Re: Standard Running Temperature
Many thanks
Harv
The Weather level of your radiator is ok ?
I think the weather pump dont work.....
Old 11-27-2003, 01:43 PM
Wink Re: Re: Standard Running Temperature
Thanks for your help,
Radiator level ok, coolant ok, been to garage today and apparently thermostat bust which is affecting water pump
best regards
Harv
Old 11-28-2003, 01:32 AM
Re: Re: Re: Standard Running Temperature
best regards
Harv
Verify the Thermostat sensor .
If you run with the climasystem turned on (the compressor) the water themperature is ok ?
Old 11-28-2003, 02:25 PM
As I understand it, there is a thermostat which controls a valve which regulates the flow of coolant around the system. When the temperature increases the valve opens further to permit a greater flow of coolant around the system, and likewise when it is cooler it reduces the flow. I'm not sure but I don't believe the compressor for the aircon has a direct impact on the coolant system for the engine.
Best regards
Harv
Old 12-01-2003, 10:12 AM
Best regards
Harv
Ok try to change the thermostat sensor.
Old 01-31-2004, 02:08 PM
a156 a156 is offline
Harv128,
Your car is displaying the same symptoms as mine and I had to change the water pump.
The water pump has a nylon impeller that cracks and spins on the shaft. The situation starts with a slight 'running hotter than normal' condition and progresses to overheating at low revs.
Sorry to convey the bad news because the repair is very difficult.
Needless to say I checked out all of the obvious things such as radiator cap and thermostat. I was even tempted to install an aftermarket cooling circuit boost pump.
Since the water pump was replaced my car has been running at ~75C and climbs to ~90C in traffic, this being quite good in the midst of an Australian summer.
best regards,
Ian Anderson..
Old 02-01-2004, 02:47 PM
Wink Re: Standard Running Temperature
Originally Posted by a156
Harv128,
best regards,
Ian Anderson..
Thanks for that Ian,
You were absolutely spot on, I saw the cracked impeller as the pump was replacd just before crimbo by the dealer under warranty.
Good news was it didn't cost me a penny, bad news was as you said it was a difficult job and by the time the problem was identified, parts brought in and pump replaced, it was off the road for nearly 3 weeks.
Best regards,
Harv
what is the normal running temperature? jbkleash Wrangler 8 03-12-2009 05:38 PM
runs horrible at about running temperature scott83 Ranger | Courier 10 12-24-2007 12:38 PM
Normal Running Temperature? SonofSparks Montana/Montana SV6 1 06-02-2006 07:11 AM
oil cooler problem contributing to higher running temperature? landlocked Camry/Camry Hybrid/Vista 2 03-31-2006 02:19 AM
1992 Bonneville Stalls at running temperature. RedDeath Bonneville 11 03-21-2004 05:19 PM
